Results 1 to 7 of 7
Thread: Weight!
    Lightbulb Weight!
    So my question is this;
    I assume that the factory weights of our early cars are indicated when the car is 'dry' - no oil, brake fluids, gas etc...Once we've tanked up with gas, filled with all fluids, etc...how much weight does this add to the factory 'specs.'?
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Senior Member curtisaa's Avatar
    Pasadena, CA
    Gas and oil
    I believe gas weighs 8lbs/per-gallon. Oil is a bit more...
    Curt,
    Gas is about 7 lbs. and water is about 8 lbs... Had to remember that stuff a long time ago for getting right at minimum SCCA class weights...
    I thought that the factory figures were 'wet' with 1/2 tank of gas.
    I also think I remember that a 69' is for sure the lightest long LB stock 911 made.
    Weights
    Given the penchant for shaving ounces off these cars, e.g. removing glove box doors, clocks, etc., for those who want to nail this one down to a gnat's ass, gasoline weighs 5.8 to 6.5 lbs. per gallon (U.S.)--temperature dependent.
    I don't think they ARE dry -- they are according to a DIN spec.
    You would need to look up that (old) DIN spec and find out what it entails.
    I assumed that "curb weight" meant full of all fluids other than gas, tank 1/2 full...All factory tools, carpeting, etc. also in place...
    DIN = Deutsche Invented Number.
    Tom
    Early S Registry #235
    rgruppe #111
  1. anyone know the approx weight of a 2.4?
    By EARLY911ZOO in forum Technical Info
    Last Post: 04-29-2013, 08:07 PM
  2. Weight watchers
    By Tom F. in forum Technical Info
    Last Post: 03-24-2013, 04:07 PM
  3. Weight of cases
    By Dave Mitchell in forum Technical Info
    Last Post: 11-30-2009, 05:32 PM
  4. 911 muffler weight?
    By demo in forum General Info
    Last Post: 11-29-2006, 03:16 PM
  5. engine weight
    By timothfarrar in forum Technical Info
    Last Post: 05-13-2003, 06:15 PM
