Thread: Weltmeister sway Bar
    Member, Human Race wit61's Avatar
    Jan 2003
    Pennsylvania, Northeast
    I am planning to install a front sway bar. Has anyone had experience with the weltmeister sway bar kit (or have a stock assembly for sale)? TIA
    http://www.classicvelocity.com
    70 911T Targa
    70 911E
    73 914
    If you go flying back through time and you see somebody else flying forward into the future, it's probably best to avoid eye contact....
    Goldmember ttweed's Avatar
    La Jolla, CA
    I have used them in the past, and they are adequate, but not the best quality available. The Weltmeister kit for the front anti-sway bar upgrade includes only fixed droplinks, IIRC. If you use it, buy at least one adjustable droplink so that you can install it with zero preload after corner balancing.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    I have a Weltmeister kit on the front of my 914-6, which as you know, had none fitted originally. I'm happy with the weltmeister reinforcing plates that I welded on the chassis, as well as the adjustable drop links, but I have a few dislikes. They are:
    >The drop links can not be adjusted anywhere near the soft end of the adjustment range because they end up at a sever angle and bind at the a-arm attachment (oddly, the little u-shaped clevis was already on the original a arms - I guess they came out of a 911 parts bin).
    >The bushings are very hard, and make all kinds of noise, even if lubricated per the instructions.
    >The hardware on the drop links is SAE. It obviously works, but I find it annoying!
    If you want adjustable, I'd look elsewhere. If not, I'd use factory parts in the diameter of choice.
    Lee
  1. WTB: Adjustable spring plates Weltmeister / Sway-a-way for a SWB
    By Mdezeeuw in forum For Sale: 911 Parts
    Last Post: 03-01-2013, 03:29 PM
  2. Weltmeister/Automotion Front & Rear 19mm adjustable Sway Bars
    By M_deJong in forum For Sale: 911 Parts
    Last Post: 03-03-2011, 07:19 AM
  3. WTB Weltmeister air Box for 70-73 T/S
    By RW7810 in forum For Sale: 911 Parts
    Last Post: 03-13-2010, 08:14 AM
  4. Weltmeister for a 901 ??
    By JHunter in forum Technical Info
    Last Post: 11-11-2007, 04:06 PM
  5. 19mm Weltmeister rear sway bar
    By p-thomas in forum For Sale: 911 Parts
    Last Post: 08-07-2007, 08:33 PM
