Thread: Condoms for wind-duh switches?
    Nov 2002
    Worshington State
    Right before the Mighty-Whitey went in for its heart transplant, I was driving through the rain to work. When arriving at the covered garage, to swipe my badge, the driver's window refused to respond. Same for the passenger. After the car sat all day, and presumably dried out, both windows sprang back to life (as fast as 30 year old motors can 'spring'.
    I am assuming the short was caused on each switch independently, but don't know it as a fact. I was thinking about wrapping electrical tape around the switch's plug-in but that seems rather lame. Any BTDT?
    And for those the least bit tempted; No in advance. I'm not going to pull them weighty monsters out.
    Thx
    Jun 2003
    Toronto
    I've got a 70 with pw's, the switches have rubbber moulded boots that slip over the contacts at the back, yours might be missing or the boots have worked loose and have fallen down into the door.
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    You might take a look at the round multiplug that connects all the wires between the leading edge door cavity and the interior under-dash. If it is not quite secure and tight it may allow water in, causing the problem. I think the passenger door switch gets power from the driver side, so one plug could affect both sides.
    Just a thought. I have taken both doors apart trying to chase down power window failure spending hours just to find out the plug had worked loose. Doh!
    RGruppe #183
    Nov 2002
    Worshington State
    Jens,
    We have all been there, and probably several times too many! Thanks for the info, I will check it out.
    Rick
  1. FS: Early Targa door with window and wind wind with glass
    By jerryg in forum For Sale: 911 Parts
    Last Post: 11-25-2013, 10:43 AM
  2. FS: Early Targa door with window and wind wind with glass
    Last Post: 09-29-2013, 03:38 PM
  3. Extracting an SWB Wind Wing
    By gsjohnson in forum Technical Info
    Last Post: 08-02-2013, 04:25 AM
  4. Black 3.8 gone in the wind.
    By VIper Green E in forum General Info
    Last Post: 06-23-2006, 04:47 PM
