Thread: Engine Compartment Sheetmetal
    Feb 2004
    Whitefish Bay, Wisconsin
    I want to strip and powercoat the engine compartment sheetmetal as close as possible to original on a '68 S. I assume
    that semi-gloss is appropriate. I would also like to get the fan done. If those of you who have done this can offer guidance, I
    would appreciate your input. Thanks, Jim
    I have had my sheet metal powder coated satin black. The fan and housing was beadblasted and clear powder coated
    Semi gloss on the sheetmetal. You won't regret it as the stuff is as tough as leather and takes abuse pretty well (doesn't chip).
    I powdercoat everything these days from motorcycle frames to cylinder jugs on the same.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
  1. FS-NOS factory engine sheetmetal piece
    Last Post: 10-18-2012, 08:58 AM
  2. 67S Engine sheetmetal NEEDED
    By Rennman in forum For Sale: 911 Parts
    Last Post: 03-31-2011, 06:11 AM
  3. Engine Sheetmetal Finish?
    By 71-911T in forum Technical Info
    Last Post: 07-21-2008, 06:54 AM
  4. FS engine compartment light
    By Fritz A. Ficke in forum For Sale: 911 Parts
    Last Post: 07-07-2008, 05:50 PM
  5. Engine Compartment Pad
    By larry47us in forum Technical Info
    Last Post: 03-20-2007, 08:42 PM
