Thread: more help
    more help
    when I start up right now the engine revs up real high.
    what can be causing that?
    I have to shut it down right away.
    I don't know if it fuel delivery or air?
    1972 911t Coupe(being Restored)
    1973 911t Targa(parts Car)
    2001 Audi A4 Quattro
    2004 Ford F150
    Re: more help
    Did you check all of the throttle linkage? Including the throttle handle between the seats?
    yes I closed the throttle all the way , can the vaccume pull them open?
    2004 Ford F150
    NO... what-ever-your-name-is (Man, I'm an old guy that still has trouble with not being able to address someone by name)
    ... it's not the vacuum
    The throttle control for your car is totally mechanical...(almost)
    Follow it from the pedal (sometimes the carpet gets screwed up)
    ... out the other end where it exits the tunnel, up to the bell crank, all the way to your throttle bodies...
    There has to be a bind, kink, or obstruction somewhere that is inhibiting the throttle from returning to it's normal position.
    Hope this helps...
    Good luck and let us know whatsup
    ok all cables are disconected , to the engine .
    how closed should the
    MFI be? is just a 1/16 of a inch alot?
    2004 Ford F150
    Yes, 1/16 is a lot. After removeing the air cleaner, look down the throttle stacks and the butterflies should be closed. I am sure it's a linkage problem somewhere. Did this situation just happen?
