Thread: 67S rear rotors
    67S rear rotors
    Shortly ago there was a thread on using 944 rear brake rotors on 67S rear applications. I think ttweed had used this set up and it worked. I tried a search and it (or I ) failed. Any help?
    Jan 2003
    NW Indiana
    Rick,
    Here you go.
    '67 S brake rotor thread
    There really is amazing info. on this Board.
    Brian
    '71T
    R Gruppe #299
    Thanks Brian !!
    Just what I was looking for!
    Rick,
    If you need to ask any questions about the 944 brake rotor job feel free. I performed it with ease (and success).
    Bram.
    Thanks again.
    Your explaination was pretty good. I have one original rotor that was turnable within spec. I will bead blast the rest of it and paint it with OE gray paint and it will be like new.
    I have put up a post on the board here, and on Pelican looking for one more used one to restore. If I get no responce, then I will go the 944 route on both sides.
  1. SWB Rear Rotors
    Last Post: 10-23-2008, 05:37 AM
  2. Rear Vented Rotors
    By pacarguy in forum Technical Info
    Last Post: 06-30-2008, 04:12 PM
  3. SWB Rear Rotors - 944 vs. Stock
    By Neunelfer in forum Technical Info
    Last Post: 04-01-2008, 09:10 AM
  4. 67S rear brake rotors
    By Rick Cabell in forum Technical Info
    Last Post: 01-03-2006, 10:19 AM
  5. 67 911S rear rotors $$$
    By aracerx in forum General Info
    Last Post: 08-10-2005, 07:47 AM
