Thread: cam identification
    cam identification
    Anyone have insight on identifying the cams?
    '71 911S Targa
    bump
    '71 911S Targa
    Cam Identification
    What are the Part ID #'s stamped on the shaft centers?
    The ID's will tell you what the shafts were originally ground to. However, it is possible that thye cams have been reground to different spec's. Only way to know if the cams have been reground is to have them analyzed. Webcam can do this for you and tell you exact lift, duration etc. They will also regrind them for you for around $400 and up.
    Hope that helps.
    next time I pull the covers I'll have to check the numbers, any idea on who to contact on what the numbers mean?
    '71 911S Targa
    Jan 2003
    NW Indiana
    When you get the numbers put them up here. I had the same problem with the cams in my engine. They didn't have a Porsche parts #, instead I was able to figure out the #'s were from Web Cam after I discussed with several guys here.
    Brian
    '71T
    R Gruppe #299
  1. Caliper identification
    By Bantam in forum Technical Info
    Last Post: 08-29-2013, 07:02 AM
  2. '66S identification help
    By Jones in forum General Info
    Last Post: 05-06-2013, 01:24 PM
  3. Part Identification Help
    By classic in forum Technical Info
    Last Post: 07-27-2012, 04:35 PM
  4. Identification - Air cleaners
    By gilbert911 in forum Technical Info
    Last Post: 01-14-2009, 10:51 AM
  5. H1 Identification
    By gtgroupe3 in forum Technical Info
    Last Post: 03-14-2007, 12:38 PM
