Thread: un-used pully attached to cam?
    Question un-used pully attached to cam?
    Alright we were thinking of doing the carrera tensioner upgrade but don't know how they would fit considering this (pully thing?), to be quite honest i don't know what it is or what it is for, cause we can't see that it has ever attached to anything. (we were thinking mabey smog pump at on time?) So i guess first of all: what is this seemingly worthless thing and second is can i remove it in favor of some diff chain housings and what-not? Third i suppose is to be asked only if the second was answerd yes; how is it done?
    any help will be greatly appreciated.
    -68'911
    i posted onpelican too so if you post one place no need to post at the other, thanks again!
    68' 911
    81' 280zx turbo (for sale)$4500 obo
    96' Honda Prelude
    03' Nissan Altima
    Maybe you have camshafts from a MFI car? The MFI pump is driven by a pully on one of the cams...
    Goldmember ttweed's Avatar
    La Jolla, CA
    I believe the '68 911 had to have a smog (air injection) pump in the US, which is why the "S" was not imported that year. Without seeing it, I would guess it may be the drive for that, and the pump has been removed at some time in the past. The left chain housing has a seal for the shaft to come thru and drive the pump on the type 901/14 engine.
    As far as the Carrera tensioners go, I wouldn't do them on a 2.0 engine. They are much more expensive to do on an early car, and the chains and tensioners just aren't stressed as much in the 2-liter as in the later, larger displacement motors. When mine went out on the '67S, I just replaced the old ones with the newer 930 type (self-contained, non-pressure fed), and upgraded the chain ramps. No problems since. Much cheaper and simpler, and they can be rebuilt if necessary in the future.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    thanks for the info guys, i think i'll lose the pully and stick to the tensioner collars that i already have.
    -68'911
    68' 911
    96' Honda Prelude
    03' Nissan Altima
  1. correct pully size for a 68
    By preS in forum Technical Info
    Last Post: 10-10-2012, 05:02 AM
  2. WTB - crank pulley and fan pully for 3.0
    By moparrob in forum For Sale: 911 Parts
    Last Post: 08-22-2010, 04:43 PM
  3. RSR Bottom Pully?
    By sezme in forum Technical Info
    Last Post: 03-02-2009, 12:59 PM
  4. WTB - RSR lower pully
    By sezme in forum For Sale: 911 Parts
    Last Post: 03-02-2009, 05:30 AM
  5. WTB Crank pully for MFI car
    Last Post: 02-09-2006, 04:33 AM
