Results 1 to 2 of 2
Thread: Adjusting valves too tight or too loose
    When adjusting valves, is it better to err on the side of too loose and have to listen to them rattle or too tight and worry that about power loss?
    Rich
    1970 911S Targa
    Rich
    1970 911S Targa
    Loose valves are happy valves. You can burn a valve that it too tight.
    Tom
    PS: If you adjust them and they get noisy again after a few miles it's not the adjustment, it's your guides. They are worn out.
    Early S Registry #235
    rgruppe #111
  1. Trailing arm w/bushing to tight for chassis mount :-(
    Last Post: 04-13-2011, 09:29 PM
  2. Tight clutch on '68 911
    By Fritter in forum General Info
    Last Post: 06-03-2009, 12:47 PM
  3. water tight targa?
    By holy s in forum General Info
    Last Post: 05-04-2007, 02:38 AM
  4. Weber air adjusting screw set up
    By cosley in forum Technical Info
    Last Post: 09-27-2006, 03:28 AM
  5. Adjusting Webers
    Last Post: 07-04-2004, 08:00 AM
