Thread: More American Racing questions
    Could anyone help me with this.
    Specifically - on 7x15's what offset would fit under the arches of a 72 911 with rolled lips?
    (I'm running 205x50's on the back and 195x50's on the front)
    'American Racing do not show any applications for Porsche at all in their catalog.
    I believe, however, that your wheels have a 5 bolt 5" PCD and 105 series wheels are available with this pattern.
    The standard 15 x 7 has a 3 3/4" backside setting which equates to a 6mm negative offset. These wheels are priced @ £145 ea. + VAT.
    Alternatively, American Racing offer a version of the Torq-Thrust II wheels with painted spokes in their Vintage Custom Shop range. These can be manufactured with either a 4" or 4 1/4" backside setting - equivalent to an offset of 0mm & 6mm positive respectively. These are priced @ £200 ea. + VAT.
    If any of these are suitable for your vehicle, I will check with American racing to see if they are aware of any clearance issues on your vehicle.'
    Cheers
    Mike
    To ask is to seek denial
    American Mags
    I an interested in buying a sect of Americal Mags for my 71 911. Please email with contact information. (johndilger@aol.com)
    John Dilger
    5" PCD?
    Mike,
    Are you referring to the Bolt Circle Pattern/Diameter since you mentioned 5-lug? The B.C. should be 130mm.
    I need to check the Back Space on a wheel to make sure....
    The original 7" aluminum Americans had approx 4 3/4" backspacing.
    5" bolt circle, while close, is not the same as 130mm. You may want to start trollling around early Nova web boards looking for these wheels. The 7" Porsche pattern wheels are very popular with some 66-67 Nova guys because they are the only American that will allow the use of a 7" rim on a stock rear end. Go figure
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  1. American racing wheel, ONE WTB
    By Rennman in forum For Sale: 911 Parts
    Last Post: 05-14-2011, 03:56 PM
  2. American Racing Wheels? Mag?
    By mrbmw2002 in forum Technical Info
    Last Post: 06-03-2010, 06:14 AM
  3. American Racing Wheels
    By Alex Webster in forum General Info
    Last Post: 05-27-2007, 06:46 PM
  4. WTD American Racing wheels
    By Alex Webster in forum For Sale: 911 Parts
    Last Post: 12-11-2006, 03:49 PM
  5. American Racing mag ID markings?
    By Jens in forum General Info
    Last Post: 03-16-2004, 03:55 PM
