Thread: 1967 911s
    1967 911s
    Hi everyone
    I'm looking to buy a 67S and wanted to know how I can determine if the engine is the original one installed before I buy. Would the chassis number on the data plate have the S on the end or would it have just the numbers? It has an engine serial number that fits into the engine number range, but is it original? Any help would be greatly appreciated!!
    no way to really tell since engine numbers weren't sequential to the car VIN's back then. If the engine number is in the range of
    960001 thru 96111144 it's probably correct, but only factory records (read kardex costing over $100 these days) will tell for sure which engine came with which car.
    would the chassis# on the data plate have an S on the end?
    Thanks again
    Seattle WA
    Yes, the data plate will have an S on the end of it. Best place to check is in the trunk, just behind and to the left of the spare tire.
    In terms of telling whether the engine is correct to the car, you could post a chassis number and engine number, and one of us will be able to tell you if it's correct as those of us who received the registry listings will be able to tell from other cars serial numbers what the correct engine number range should be.
    Perhaps that's not clear, but there is an early S registry, and in the questionnaire we filled out when we joined the club, we list are serial number , and our engine number. This list is mailed out to members of the club.
    One thing to make note of, the ID plate that is on the door frame only holds six digits, therefore sometimes the S looks like it's stamped in as an afterthought or as an attempt to deceive.
    In addition, the 1967S has a lot of detail trim that the stock 67 911 does not have.
    Regards, Eric
  1. Replies: 1
    Last Post: 08-04-2013, 03:48 AM
  2. WANTED; WTB 1967 911S with incorrect engine or 1967 rolling chassis
    By almostblue in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-15-2012, 05:43 PM
  3. Jan 1967 Car and Driver 1967 911S review
    By 88cs in forum For Sale: 911 Parts
    Last Post: 07-23-2011, 01:12 PM
  4. Pending Russo & Steele Auctions of 1967 911S & 1969 911S
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-25-2011, 11:11 AM
  5. 1967 911s & 1967 911s rolling body shell to trade
    By RJ Schwartz in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-20-2010, 03:52 PM
