Just put on new rotors/pads and rebuilt the front calipers.
Now my brakes squeak at low speed braking.
What can be done?
What can be done?
thanks George;
what causes the brakes to squeak?
Is there any other solutions?
I think that the brake squeak/noise is caused by the pads vibrating/oscillating between the rotor and the caliper/piston. HTH.
Any suggestions; I am getting desperateOriginally posted by 6 Shooter
I think that the brake squeak/noise is caused by the pads vibrating/oscillating between the rotor and the caliper/piston. HTH.![]()
Hey Dwight,
Yeah, I noticed that the other morning pulling into the Bakery. I saw (somewhere) some spray that's supposed to stop the skweaking. I've never tried it but if you are desparate.... I think it was at Kragen's auto (seriously). Let me know.
Otherwise, I'm sure upgrading to some racing cabon pads and cross drilled Zim's would do the trick![]()
Had a great time driving your car BTW. We'll have to do it again soon. I've got a 70' T adn a 69'T (both Albert Blue) recruited for the next coffee run as well.
Chris Purpura @civilizedmisfit
___________
Member #479
Current Cars:
1972 911T aka The "Civilized Misfit" Build
See: https://www.excellence-mag.com/issue...vilized-misfit
Miss February - EarlySRegistry 2023 Calendar
1968 911S Ossi Blau/Beige Corduroy
Past Cars:
2019 911 Carrera GTS (sold, no regrets)
73S - #1100 (restored and now somewhere in Europe)
1997 993 Carrera 4S Black on Black (sold)
There is some "anti-squeal goop" sold in most auto parts stores that you put between the piston and backing plate to stop the vibration, but I have never used it, so don't know how well it works and what downsides there may be. Beveling the leading edge of the pad as GeorgeK suggests is a good idea. My Pagid orange pads squeak like crazy when cold under light application of brakes, but when you step on them hard, no squealing. I do believe it is a vibration problem, so the goop may dampen that.Originally posted by scargo70
Any suggestions; I am getting desperate![]()
Good luck,
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
PCA National DE Instructor
Read my surf novel!
My problem exactly.Originally posted by ttweed
Good luck,
TT
