Thread: Transmission codes & serial numbers
    I've been having the hardest time finding a list of transmission codes and their corresponding serial numbers for the 911 from 1965-present. I've had no problem finding engine & chassis numbers, but the transmission info has been extremely elusive. I've done a google, but to no avail. I'm in the market for a couple of transmissions, but have no way of telling exactly what the specs are for the transmissions i'm looking at. Please help.
    Thanks.
    split,
    As far as I've found (or not found) there is no single source for the trans. codes vs. serial numbers. There is however all the info you need in the...The small format factory 'spec' books
    For the early cars you would have to buy 3
    Performance Products has'm
    '65-'68 901280 $32.95
    '69-'71 901283 $34.95
    '72-'73 901284 $27.95 includes specs on the 2.7 RS
    ... they also have 7 more through 993's ranging from $12.95 to $24.95
    Hope this helps,
    Tranny numbers
    Thanks for the info! I'm placing my order tonight.
    Thanks again, Chuck.
    Here is the info. you are looking for I believe-
    Porsche Transmission Codes & Serial Numbers
    It's one of my many bookmarks from the all knowing / all powerful Early_S_Man's library of useful info.
    early s man
    Ahmen.
  1. 915 Transmission numbers..what do they mean?
    By davewadd in forum Technical Info
    Last Post: 05-17-2012, 04:27 PM
  2. Transmission Serial # ID?
    By Dave Pugh in forum Technical Info
    Last Post: 03-05-2012, 06:17 PM
  3. Transmission Numbers
    By LongRanger in forum Technical Info
    Last Post: 04-02-2011, 10:34 AM
  4. Corrections to serial numbers
    By jim schrager in forum General Info
    Last Post: 02-07-2009, 07:44 AM
  5. 911T engine serial numbers
    By lotus15racer in forum Technical Info
    Last Post: 12-11-2004, 10:00 AM
