Results 1 to 10 of 19
Thread: Which Brake Fluid to use ?
    May 2008
    Sydney
    Hi Guys,
    Just wondering which brake fluid do you guys use and why ?
    Dot 4 or Dot 5, given the car is going to be 95% Street use
    Cheers
    Shipard
    Clayton Shipard
    Sydney, NSW Australia
    1972 911 2.4S
    2000 Boxster S
    Apr 2003
    Portland, OR
    I have been alternating between ATE Blue and Gold. Why? Good BPs, only about $10/liter and I can tell when the old stuff is fully flushed (color changes).
    Harry
    Member #789
    2009 MB C300
    Almost any thing better than that 'silicone' stuff , the pedal is always "spongy" with silicone brake fluid, yuk!
    Clayton...
    A good old standard for street applications is Castrol LMA
    Inexpensive and usually available at your local flaps:
    Exceeds DOT 3 and DOT 4 requirements. Unique Low Moisture Activity (LMA) Exceeds specifications SAE 1703, SAE 1704, ISO 4925, JIS K2233 and FMVSS No. 116 DOT 3 and DOT 4.
    Castrol LMA Specifications:
    DOT Rating - 4
    Dry Boiling Point - 446°F
    Wet Boiling Point - 311°F
    Compatible with other fluids - Yes
    As mentioned The ATE Super Blue/Gold is an excellent fluid for track or street..
    And as noted stay away from the DOT 5 silicone stuff....you don't want this!
    Jun 2008
    Main Line, PA
    Good to hear that GTLMA is the porsche flavor of choice as well. Universally used in british car circles as well (other than those who must have the red look of girling crimson).
    May 2008
    Sydney
    Thanks Guys
    Thanks for the advice, the car is currently up on jack stands so I thought i may as well replace the flexible brake lines and bleed the brakes at the same time
    The car is slowly getting ready to be registered.......I can hardly wait to be able to drive it. That said it is going to be about 2 months, work and budget permitting before its ready to be driven on the road regularly.
    Thanks again guys, it great to be part of the early 911 community
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    I use the Castrol GT LMA. It performs well in my humble opinion. I just wish it was that cool blue color like the ATE stuff so I could see it in the fluid tank, vent tube, and when bleeding/flushing the system.
    LMA is on the low end of a group of HD fluids. Perfectly fine for street use though. Some HD fluids and specs:
    http://members.rennlist.org/911pcars/brakefluid.htm
    Sherwood
    May 2008
    Sydney
    Thanks for the helpful advice I bought the castrol brake fluid and replaced the fluid today. It was also to see if this would fix the slightly sticking left front brake caliper........good news it fixed that issue and now all the calipers seem much happier........and the brake pedal feels ten times better.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    Quote Originally Posted by Flieger
    Blue dyes your reservoir....Use ATE Gold its basically the same as the Blue without the dye. We don't put any ATE blue in cars if we can at all help it )only if customer requests).
    d
  1. RSR Brake fluid reservoirs?
    By Mike_Moore in forum General Info
    Last Post: 07-01-2015, 05:42 PM
  2. WTB brake fluid reservoir for 73 RSR
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 04-17-2012, 01:03 AM
  3. FS: Brake Fluid Reservoir
    Last Post: 08-03-2008, 05:54 PM
  4. WTB: 65-67 brake fluid reservior
    By Rich Lambert in forum For Sale: 911 Parts
    Last Post: 05-02-2008, 06:49 PM
  5. WTB: 65-67' Brake Fluid Reservoir
    By jhora in forum For Sale: 911 Parts
    Last Post: 10-20-2006, 12:13 PM
