Thread: Points gap and dwell for 1974 Carrera
    May 2009
    Baton Rouge, Louisiana
    Hi all
    Would someone please provide me with the recommended points gap and dwell specs for a 1974 carrera?
    Thanks in advance
    Gary
    Gary,
    To clarify; this is a U.S. '74 Carrera 2.7 CIS 'G' series car... yes?
    Cheers
    May 2009
    not exactly
    Well not exactly....
    I have a 68 with a 2L aluminum case that now lives at 2.7L and I was told was built to RS specs with a little compression boost. The car has webers. Anyway the distributor is a later model affair, a 231 184 007, best I can tell circa 1974. I was curious what the specs might have originally for the distributor.
    I ask because when I set the point gap as recommended for a 68 the dwell is about 25 degrees, IIRC. My car has a permatune box and maybe the dewll is no longer significant, but I just wanted to know what was recommended and none of my references go into the seventies. The car runs well, I was mostly curious re the dwell and if I should expect short points life.
    Again, Thanks
    Gary
    38 degrees but it doesn't make a big deal with CDI.
  1. WTB: 1974 911 Carrera
    By Auto*Legends in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-18-2013, 08:08 AM
  2. Points Gap, dwell & timing?
    By pwd72s in forum Technical Info
    Last Post: 08-10-2003, 05:17 PM
