Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: MFI starting enrichment temp sensor - '73 911S
    I suspect the subject part is not working properly. Does it change the amount of fuel that gets squirted depending upon the temperature? Can someone please provide a part number and tell me where it is located?
    thank you very much!
    73 911S Targa
    Cold start
    I think this is what you are referring to...maybe an expert can provide the info you need.
    Apr 2004
    35,000 ft
    I'm sure someone can post a photo.....but often it is a failure of the double-hose (hose within a hose) that goes from the heat exchanger to the temp sensor....the hose ends sort of to the rear (of the car) of the MFI pump, or head up from the ignition distributor....basically the top of the fan housing, on the left side.
    so, the temp sensor senses temp of the heat exchangers, the factory put one of those cardboard hoses (now likely superseded to vinyl) inside another one of those hoses....if the outer hose fails, the temperature readings are inaccurate....otherwise, they often get replaced with any ordinary hose that a mechanic has laying around.
    Apr 2004
    35,000 ft
    here's a good photo of the hose I had in mind, attaches to the thermostat on the MFI pump, the hose passes thru the ignition coil wire
    http://members.rennlist.org/analogmike/myengines.jpg
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by Boulder Bob View Post
    I'm no expert and will be corrected if what I write is not correct, but I believe the thermo-time switch (correct part# 911.617.117.00 as provided in pic above) closes the circuit (opens the enrichment solenoid) on a metered time basis but does not affect how 'open' the solenoid is. The enrichment solenoid (on the MFI pump) is what is opened per the current from that sensor in the crankcase cover. Make sense?
    The sensor (thermo time switch) is located in the crankcase breather cover, centerline of engine, underneath your air intake assembly, on the left, at the back (front of car) of engine. It works within a certain temperature range
    What symptoms are you experiencing?
    1969 S Coupe #761
    Early S Registry #1624
    cold ambient (< 60 deg F) starts pretty well (one second of cranking, stop, count to 10, crank again, fires right up) - hot ambient, cold start (90 deg F) starts crappy (lots of cranking and runs poorly for 30 seconds)
    "hot Start" (within 20 minutes after full warm up) starts great
    "warm start" (hot day after sitting for 2 hours) starts crappy
    I follow the starting procedures as outlined in the owner's manual
    thanks for the help
    73 911S Targa
    with the gas these days, i always pull up the hand throttle to start when hot also. I think, but stand to be corrected, that the fuel boils off in the line vapour lock, due to the heat and the alcohol in the fuel.
    Aug 2005
    VA
    I am a bit confused, What tells the cold start not to work when the engine is hot? A picture would be great.
    I hooked up the cold start (on top of the fuel filter) to the starter circuit. Engage the starter and power goes to the cold start thing on top of the fuel filter. Works great when cold but can flood when hot.
    Aug 2009
    Atlanta
    Quote Originally Posted by cmcfaul View Post
    What year is your car?
    In short, the temperature sensitivity of the cold start valve and/or enrichment solenoid depends on the thermo time switch. This switch says 'too hot to engage'.
    I'm not experienced enough to speak too strongly, but I would be concerned with your current setup connected directly to the starter circuit. Someone will comment probably.
    For 69, there are two switches, one for the solenoid on top of the MFI assembly and one for the enrichment solenoid on the pump. For the 2.2 engines, the two switches went away. Here is the factory manual's explanation of the thermo-time switch:
    1969 S Coupe #761
    Senior Member mrg3.6's Avatar
    Nov 2007
    United Kingdom
    Quote Originally Posted by sonett43 View Post
    As an ancillary question on the same subject, I am just about to swap out my heat exchangers for headers on my 2.7 mfi so how do I deal with the enrichment circuit?
    Thx
    Martin
  1. WTD Oil temp sensor for 68 (Porcelain style)
    By beetle08 in forum For Sale: 911 Parts
    Last Post: 12-02-2012, 11:08 AM
  2. A nice starting bid for 1969 911S!
    By G69 in forum ErsteGruppe
    Last Post: 08-14-2012, 02:31 PM
  3. Sweet '73 911S on Ebay now starting $85,000!
    By duaneh1 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 08-06-2011, 08:49 AM
  4. WTB: LM-1 O2 sensor
    By orange911 in forum For Sale: 911 Parts
    Last Post: 05-19-2009, 07:22 AM
  5. Sensor on oil breather
    By kenikh in forum General Info
    Last Post: 08-25-2005, 08:27 PM
