Thread: US vs RoW gearing
    US vs RoW gearing
    All,
    was there a significant change in 901 5-speed gearing between 1967 and 1968? Reason for my question is a recent comparison between my '68 and my buddy's '67. Both are 901-5speed trannies, but mine runs at significantly higher RPMs. Both are sporting 195/65 R 15 tires, and both are 2.0 mated to a 5 speed. At 80mph (per the speedo, equals 74mph according to my GPS) his is running 3400rpm, while mine is at 4k exactly. At 70 mph (Speedo) mine is at 3600 and at 3100 rpm I am doing 60.
    We recently discovered, however, that his 911 was a euro delivery (Pon Amersfoort Holland). So if the US cars had no changes, could his be Euro gearing that is soo much longer?? Granted, off the line is a nice experience with mine, at highway speeds the revs are up there...
    Any input from those in the know??
    Thx
    ~J~
    air cooled only
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    This link should be very useful to you
    http://www.early911sregistry.org/for...ear-Info-Sheet
    1969 S Coupe #761
    Early S Registry #1624
    Thank you for that VERY informative link - but does that apply to both US and Euro spec cars? We are both running the same tranny.... still makes very little sense.
    ~J~
    air cooled only
    It's no surprise that a european car would be geared longer. Their highway speeds were not limited like ours back then. It might also be a different rear end ratio.
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by Jules Dielen View Post
    Okay, first determine the actual transmission type and the serial number for each. Then we can determine the original ratios.
    If the original ratios were the same, then someone has changed the gearing. Provide me with the VIN`s and I can try and see if there is a pattern to the applications.
  1. Gearing Question
    By Sisuman in forum Technical Info
    Last Post: 06-23-2012, 05:07 AM
  2. 901 gearing for a 2.5l engine
    Last Post: 07-05-2010, 03:58 PM
  3. 915 Gearing References
    By gtgroupe3 in forum Technical Info
    Last Post: 02-11-2009, 01:13 PM
  4. Help with Gearing..
    By Mudi in forum Technical Info
    Last Post: 04-18-2008, 07:50 AM
  5. 901 SWB trans gearing
    By Fritter in forum Technical Info
    Last Post: 12-02-2007, 04:05 PM
