Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Are these standard items on a Early 69t ?
Size:  83.0 KBName:  DSC00999.jpg
Size:  68.8 KBName:  DSC00997.jpg
Size:  75.9 KBName:  DSC00995.jpg
    Hello again.... sorry for so many questions but trying to research the cars components,
    1) the first two Pictures are of two round threaded housings found on each side of the parcel shelf (about a inch in diameter)
    WHATS ARE THEY FOR?
    2) the third and fourth pictures are of a hole found underneath my dashboard between the clock and the speedo unit (about 2 cms diameter)
    WHAT IS THIS FOR?
    lee
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Regarding #1: Anchor points built into rear shelf are normal
    Regarding #2: Hole on left (above ignition) is normal place for push/pull knob for rear wiper. On right could be other accessories.
    1969 S Coupe #761
    Early S Registry #1624
    Hi Lee. My 69 does not have holes on the rear shelve panel. It might have been added for seat belts? Or a child/infant seat?
    As far as the hole on the dash I'll check my car. I don't think I have one there.
    May 2005
    Oroville, CA
    My Karmann has the package shelf mounts. It may be a Ruetter/Karmann thing.
    H
    Yes RHD car, no 8, 119100008 vin, ex south africa car....
    thanks Lee
    What's TTG light?
    My kardex does not list a rear wiper so must be an accessories or after market I guess..
    Thanks lee
    My Karmann '69T has the package shelf mounts, generally thought to be harness mounts.
    I do not have a rear wiper, so can't comment on extra holes...could be owner molestation for accessories of some sort.
    Fog light cars had the switch, which had an illuminated knob, mounted right on the dash panel with the lighter, etc.
    If not fog light car, the switch hole was plugged with little shiney plastic button-like plug from the factory. The harness for fogs was on every car as part of the main harness, just no switch or lights.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Jul 2006
    Corvallis, OR
    Quote Originally Posted by leedurrant73 View Post
    What's TTG light?
    Thanks lee
    Through the grill. Meaning the lights were mounted through the horn grills.
    72S, 72T now ST
    Aug 2009
    Atlanta
    What's TTG light?
    Thanks lee
    If you post a pic of your kardex or list the codes on it, I will help you with what all the numbers mean.
    1969 S Coupe #761
    Ok will do shortly.....thanks
  1. WTB: Early Standard 11 Blade Fan
    By Mike_Moore in forum Wanted: 911 Parts
    Last Post: 02-25-2018, 06:26 PM
  2. FS: 2 Nadella axles, one standard one reinforced for early 911 904 906
    By scuppernongwine in forum For Sale: 911 Parts
    Last Post: 08-23-2013, 03:25 PM
  3. Aero advantage of early S bumper over standard?
    By Shaun 69 E in forum Technical Info
    Last Post: 06-06-2010, 06:52 PM
  4. fs- early items
    By vintage83 in forum For Sale: 911 Parts
    Last Post: 10-05-2008, 04:56 PM
  5. Early items available..
    By glaverbel911 in forum For Sale: 911 Parts
    Last Post: 11-13-2006, 08:39 AM
