Results 1 to 10 of 18
Thread: problem
    problem
    Hello,
    I bought a 911 2.4s a few weeks ago.
    There is a noise when I accelerate and turn left or right. It doesnt do that when I accelerate straight ahead...
    That's very strange...no?
    The noise doesn't come from the engine.
    First I thought it was the differential, but checked that today and it wasn't, I think...
    What else could it be?
    Anyone?
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    front wheel bearings? cv joints?,,,, just a guess .... My 2.4 T is non -operational; Thats a greater problem !
    What does it sound like?
    Jul 2008
    South Florida
    Sounds like rear wheel bearings... tick-tick or squeals?
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    This reminds me of when I bought my 2.4 T Coupe...everytime I turned left there was a thud coming from the rear of the car. Once I replaced the original style steel trailing arms with later model aluminum trailing arms the thud was gone.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Raise the rear of the car, grab each wheel by the outer edge and try to rock it back and forth. If you get any play, the bearing is bad and it may be the source of your noise. Hard to diagnose with your description so start eliminating possible culprits.
    1969 S Coupe #761
    Early S Registry #1624
    Does the car have a rear sway bar? Make sure it is not touching anything on the trany mount. Studs etc. gled
    does it have oversize wheels and tires?
    Thanks for the quick answers and reaction.
    Front wheel bearings were replaced and are new. That's what I thought first too, but eliminate that.
    It is a heavy tick-tick noise only when turning left or right and accelerating, leading me to the sper differential.
    When I lift the car and turn one rear wheel in a direction the other wheel does the same thing, so ...
    No play on the rear wheels.
    No sway bar.
    Just normal original tires and wheels.
    My mechanic thinks it is the oil in the gearbox.
    He says I should use low slip oil for differential gearboxes.
    Anyone familiar with this?
    Id check the CV joints for wear
  1. Here's my problem with the new 911.
    By MarkH in forum General Info
    Last Post: 07-16-2013, 04:09 PM
  2. Possible problem
    By frankmar in forum Technical Info
    Last Post: 02-20-2013, 01:00 AM
  3. PM problem
    By Cliff in forum General Info
    Last Post: 12-13-2010, 01:08 PM
  4. Problem...3.0 RSR
    By cyber2213 in forum Technical Info
    Last Post: 08-31-2010, 03:22 PM
  5. MFI problem???
    By oldautoradio in forum Technical Info
    Last Post: 01-31-2007, 12:36 PM
