Thread: Copper faced 67s Flywheel
    Member #1525 gilbert911's Avatar
    Oct 2006
    Europe
    This is mine in the picture.
    Is the pressure plate with the same copper face the only one I can use for this to work effectively?
    Thanks for your help
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    What's the part number for the PP? I see a sticker on a bag underneath it
    1969 S Coupe #761
    Early S Registry #1624
    I believe the copper face on the flywheel was to aid in heat dissipation, the copper on the pressure plate is to provide a wearing surface for the aluminum foot of the pressure plate. Back in the seventies we always used the two together with, I believe, a standard thickness disc. In 69 this changed to a non copper faced flywheel, a steel sprayed surface on the pressure plate, and a thinner clutch disc to compensate for the thicker clutch foot due to the metal spray surface. I'm sure you could use a standard steel pressure plate, and a standard thickness disc against the copper faced flywheel. The copper surfaces seemed to wear rapidly, so often the whole set-up was converted to standard issue.
    There will likely be others with better info on this!
    Oct 2006
    Europe
    Ed,
    Thx for your insight.
    Beh,
    Pic of sticker attached.
    Jun 2009
    Cape Vincent, NY
    The copper facing lasted no real time and Porsche did away with it in 69. heh, that rhymes... anyway, the replacements are non-copper faced and just fine to use.
    1968 911S 30K miles
    2006 Saturn Ion DD
    1988 Beretta GT
    1981 5-Ton Chevy stake-bed
    Air goes in and out, blood goes round and round, any variation of this is a bad thing.
    Ralph Jones, the Springfield,MA dealer rebuilt Ol' Ivory's engine in 1975. When I pulled the engine (frozen up) in 2005, the copper face pressure plate was still in place but there was no trace of copper on the flywheel.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
  1. FS: Porsche 911s 1967 Copper face flywheel.
    By yermancars in forum For Sale: 911 Parts
    Last Post: 02-12-2014, 07:01 PM
  2. AZ Copper State 1000
    By lowflyrE in forum Other Car Cultures
    Last Post: 04-14-2013, 10:58 PM
  3. 67 S copper surface fly wheel
    By Cliff in forum General Info
    Last Post: 03-15-2010, 08:40 AM
  4. FS NEW !! 901 Copper faced S pressure plate
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 03-23-2006, 12:01 PM
  5. Copper Plating on Oil Tank?
    By bobmagyar in forum Technical Info
    Last Post: 12-09-2005, 04:07 PM
