Results 1 to 7 of 7
Thread: Tips on Converting to Bosch CDI
    I am converting an early carbed car to MFI/Bosch CDI Any tips, wiring diagrams etc. I would like to do the minimum danage to the harness in the event it returns to original engine/ignition.
    50/50
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    What year and model?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    PDFs of wiring diagrams can be found here:
    http://members.rennlist.org/911pcars/WiringDiag.htm
    1969 S Coupe #761
    Early S Registry #1624
    All you need is here:
    http://forums.pelicanparts.com/porsc...electrics.html
    Post your questions here and I will answer.
    Here's some pictures of my conversion. CD is mounted on aluminum plate, mounted on rubber insulators to the shock cross bar. Out of sight when the aircleaner is on. The proper black CD coil, and the tach intermediate unit are mounted on the relay board. I made a separate wire harness sleeved in the correct vinyl that goes back to the CD box. None of this compromised the original wiring. I even kept the original resistor box with fake wires into it.
    Thanks Classic, BEH911 and 304065 for the info.
    Mr.Mayo very Sanitary and Stealthy Job!
    Larry
    Jun 2009
    Cape Vincent, NY
    Nice hide Ed! Really great attention to detail , I hope to do this at some point.
    1968 911S 30K miles
    2006 Saturn Ion DD
    1988 Beretta GT
    1981 5-Ton Chevy stake-bed
    Air goes in and out, blood goes round and round, any variation of this is a bad thing.
  1. Converting back to SWB
    By AlexJ in forum Technical Info
    Last Post: 08-24-2013, 05:22 AM
  2. Converting a 1971 2.2t into a hot rod
    By kriele in forum General Info
    Last Post: 03-30-2013, 01:26 PM
  3. Thinking of converting my 3.2L to carbs
    By CidTito in forum Technical Info
    Last Post: 05-25-2012, 04:22 PM
  4. Converting 912 to 911 6 cyl motor
    By lkadams in forum Technical Info
    Last Post: 01-22-2009, 01:35 AM
  5. Converting LWB to SWB
    By nick-moss in forum Technical Info
    Last Post: 01-31-2005, 07:04 AM
