Results 1 to 10 of 14
Thread: Rear factory Nudge bar NOS in Porsche plastic wrapping
    NOS and mint Porsche factory nudge bar in original Porsche wrapping..... Reality has set in that my car (something of a lovable beater and probably destined to stay that way) will never be "worthy" of such a cool accessory--it really deserves better. $1250 includes insured shipping to Lower 48. You can PM or email me: intl50@aol.com
    Photos added........buy the cool Porsche logo wrap and the bar is free ....................................
    Sale on the bar fell through yesterday.......lower price to sweeten the deal: $975 INCLUDES insured shipping to the lower 48
    When you say 'nudge bar', is it like this? Just curious - and amazed at the value of the parts on a 911.
    - Brian
    1966 Mercedes 250SE Cab
    Brian--No---Mine is the one that consists of one bar that mounts to the upper mounting holes for the rubber pad on the overriders. The rear pads are replaced by the smaller ones from the front overrider which mounts to the lower hole. Gasketing for the nudge bar to overrider is via a 356 overrider rubber gasket. All pretty well thought out in that regard.
    Jim
    Mar 2004
    Castro Valley, Ca.
    sounds like yours might be the companion to my front;
    http://www.early911sregistry.org/for...ghlight=bumper
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Check out the bahama yellow 69 that sold on 2shores.com if you want to see a pic of one mounted.
    1969 S Coupe #761
    Early S Registry #1624
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    Here's mine mounted on my 67S
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    Feb 2004
    Scotland
    Oops, double post
    RS#1551(sold)
    67S
    Early S reg. #681
    Jul 2008
    Holland
    Quote Originally Posted by 210bhp View Post
    Mike
    Very clear.......
    Slate Gray, Red Leather, 1968 912 HWT
    Feb 2004
    Scotland
    Tap the picture and you will find several nerf bar pictures of my car
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    The yellow one was mine. I would say that the modification of the stock bumperettes is not easy, but very doable. There are not enough holes for it to be a "bolt-on" application, so you have to carefully drill at least one hole per bumper. Also the nudge bar has a larger bolt that the factory holes, but I don't know if I enlarged an existing hole, or if I had to create another. I did use the rubber trim from a front bumperette, but it really doesn't fit as cleanly on the bottom as I would have hoped. I believe this is because the contour of the fronts do not have as sharp of a bend as the rears. I seem to remember finding a separate part number for the bumperettes that match the nudge bar, so there may be a different set of pads that fit the contour better. One other installation note. The assembly has to be made up as 1 before it can be mounted. Your measurements need to be really precise for the nudge bar holes ( or you can slot the holes and fit-remove-adjust, fit-remove-adjust...). I took a chance without slotting it, and got it with a tight squeeze. Was it worth it? Absolutely. I actually use it more for pulling (out of the garage) than "nudging". GLWS
    Olin - Member #1375
    1972 911T
    Original
    Options added
  1. WTB: Factory Rear Nudge Bar
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 06-20-2021, 02:12 PM
  2. Nudge bars front & rear w/ rear bumpertte
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 07-13-2010, 08:01 AM
  3. FS: Original Factory Nudge Bar
    By s2guy in forum For Sale: 911 Parts
    Last Post: 03-26-2010, 03:00 PM
  4. WTB: Factory Original Nudge Bar
    Last Post: 06-08-2009, 12:35 PM
  5. Rare Factory rear nudge bar - Value ?
    By Alan.uk in forum General Info
    Last Post: 04-02-2007, 07:56 PM
