Results 1 to 10 of 20
Thread: Trunk finish: Is this OEM or???
    Jun 2012
    Overland Park, KS
    I am not sure if my trunk came from the factory this way or not. Perhaps a PO worked on it... any insight would be helpful. It is a 1970T Tangerine..
    Sep 2006
    Maryland
    That looks OEM. There is considerable variation car to car, year to year. The paint is usually thin, with black paint on the shock towers extending inwards to the luggage compartment.
    Rob Abbott
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    What's your VIN? With that finish, I am guessing you have a Karmann built T...
    1969 S Coupe #761
    Early S Registry #1624
    '70 Trunk Finishes
    My '70 (Euro) looks different . . .
    http://www.early911sregistry.org/for...ty-nine/page23
    The back half (including the shock-towers) of my car looks like its finished in a thin pre-coat/over-spray of the original color
    The front half (including the spare well and battery boxes) looks like it was schutzed first, then pre-coated/over-sprayed w/ paint --- but then re-coated black after
    All sheet metal + finishes in the trunk are original --- only the black in the well was touched-up since my purchase. The beigey-smudgey stuff is some kind of contact cement used to affix the carpeting
    HTH
    Member clesch's Avatar
    Jun 2011
    Austria
    HTH
    This looks correct for the Porsche-built 1970’s I have seen so far. The only exception is the black color in the tank support/battery area. The cars I have seen had no black finish there. Although I have seen 2-3 cars that had an amber/transparent coat in that exact area. (possibly dried wax?)
    Everything else looks spot on.
    Jun 2012
    Overland Park, KS
    2323-1 is what the paint tag says.I have no clue what Option D15 is..
    '70 US S Targa Trunk Finish
    Quote Originally Posted by clesch View Post
    . . . looks correct for the Porsche-built 1970’s I have seen so far. The only exception is the black color in the tank support/battery area. The cars I have seen had no black finish there . . .
    Here are some shots of an original-un-restored US-market Targa . . .
    From the factory original 70E in 2424 burgandy I use to own
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Quote Originally Posted by beh911 View Post
    You got it. What was the tipoff?
    Aug 2009
    Atlanta
    Quote Originally Posted by nickb4 View Post
    I learn from the best. I don't have all the answers, but I know where to get them.
    So, a previous post on the same subject of course! By someone of authority, like edmayo.
    Check out this link and look at the first few things that pop up.
    https://www.google.com/#hl=en&safe=o...w=1440&bih=739
    1969 S Coupe #761
  1. Trunk carpet
    By classic in forum Technical Info
    Last Post: 12-12-2012, 03:36 PM
  2. FS: 65-66 trunk carpet
    Last Post: 10-16-2009, 05:16 AM
  3. Proper finish/paint for '72 trunk front
    By Allen Henderson in forum General Info
    Last Post: 10-10-2006, 02:25 PM
  4. Trunk - Does this look ok?
    By 72911E in forum Technical Info
    Last Post: 08-15-2006, 09:15 AM
  5. Photos of trunk finish SWB wanted
    By john_cramer in forum Technical Info
    Last Post: 03-23-2005, 05:03 PM
