Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Is this an Aluminum or Magnesium trans case?
    I don't know how to tell the difference between aluminum and magnesium on a transmission case. This is a 911/01 trans. Can you tell if it's aluminum or mag?
    http://forums.pelicanparts.com/porsc...ld-so-cal.html
    "Speed never killed anyone. Suddenly becoming stationary...that's what get's you."
    1973 Austin Mini
    1975 911S 3.2 "the blue goose"
    1973 911E sunroof 3.2
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Mag, for a 70/71 b4 the 915 trans & after the original 901/902 aluminum cases....
    so does that mean all 911 transmissions are mag? Is one more desireable than the other?
    1973 Austin Mini
    Jan 2011
    DFW TX
    I think there was aluminum 901 thru 68, then mag 901 '69 push clutch, then '70/71 911 mag pull clutch.
    Aluminum a bit stronger, magnesium a bit lighter. All depends on what's important to you.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Transmission cases switched from alum to mag mid MY 69
    1969 S Coupe #761
    Early S Registry #1624
    Is there a way to tell? Part number maybe?
    1973 Austin Mini
    Aug 2007
    Phila Pa. area
    Just look at it, aluminum is silver magnesium isn't.
    Mike
    Aug 2009
    Atlanta
    Well, a 911 transaxle type is a 70+ case, so it should be magnesium.
    1969 S Coupe #761
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by davewadd View Post
    Sure, that is easy, the AL main case has casting 901.301.101.0R and the MG case has casting 901.301.101.2R
    Dave P....this case has 901.301.301.1R as seen in the photo above. Not one of the options you listed.
    1973 Austin Mini
  1. 2,0 Magnesium case
    By Stockby in forum For Sale: 911 Parts
    Last Post: 04-04-2011, 05:36 AM
  2. WTB: Early Aluminum case or small spigot 7R case (92mm)
    By kenikh in forum For Sale: 911 Parts
    Last Post: 08-29-2008, 10:50 AM
  3. Replies: 5
    Last Post: 03-03-2008, 07:11 AM
  4. 1968 Alu to Magnesium Case change
    By Allen Henderson in forum General Info
    Last Post: 03-02-2008, 06:15 PM
  5. Do I have Aluminum or Magnesium Tranny?
    Last Post: 12-12-2005, 09:05 AM
