Thread: How many per day?
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    How many per day?
    I have a 68 911T SWT w/o engine/trans, BUT have an opportunity to buy an engine that is only 154 off in numbers (earlier though) than what the factory gave me for our engine number. Does anybody know, roughly, how many days off this # may have been for ours? Should I buy it due to its proximity in # to ours? I doubt that I would find THE actual engine, though that would be awesome. Thanks for your input.
    Hmm . . .
    Interesting idea . . .
    Well, I'd start by taking the total number of 911s built, then divide by 11 months @ 5 days/week to get a ball-park figure
    Just have to keep in mind that stuff doesn't exactly happen in order . . .
    . . . still --- might getcha some idea
    HtH
    Jun 2012
    London, Ontario, Canada
    More like 10 months with the typical German holidays, factory changeovers etc. 2 weeks at Christmas, 1 month in the summer and a lot of other holidays in between.
    Early 911S Registry # 2395
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    There are folks on this forum that can probably give you a more accurate mapping of your VIN to a particular engine number range, but here are some basics:
    I believe I read somewhere (Excellence was Expected, period Christophorus ? - can't remember which) that with the new facilities that came on line at the factory in 69, production was close to 30 vehicles per day. So if you estimate 20-25 vehicles per day for MY 68, that should get you close. It would put you in the ballpark of that engine being mated to a chassis probably within a week or two of production of your car.
    The challenge is that engine numbers weren't sequentially mated to VINs, so it can be difficult to pinpoint an exact timeframe without comparing several data points of production dates, VINs, and engine numbers to triangulate. Meaning chassis #50 might have engine #35 while chassis #51 might have engine #47, etc. Also, different models and different engine types complicate this a bit.
    1969 S Coupe #761
    Early S Registry #1624
    Jul 2008
    South Florida
    About 1750 Ts were built in '68 (excluding Sportos) so 154 away is pretty close... likely within the month yours was built.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
