Results 1 to 8 of 8
Thread: Gas leak.
    Gas leak.
    I have 73E w/ MFI. This happens to me twice. When the car sit for over 4 weeks and at the initial start up of engine,I see considerable amount of the gas leak from under the car. Then I turned the car off, cool the car for a while. And I restart the engine to bring to my mechanic,there is no leak at all, therefore we can not find where the leak come from. Do you have any idea what to look? When I keep driving the car at least 1x week,I do not see gas leak even a drop.Thank you very much for your input.
    Ryo
    early 911S registry
    73'E
    Sounds like the fuel lines are rotten. They dry out from sitting and leak when they first get fuel, but they quickly swell up from the fuel and then the leak goes away.
    -Marco
    TLG Auto: Website
    where is the drip? fuel pumps are notorious for leaks too, dry o rings.
    bob moglia
    '72 E sunroof coupe
    Thank you guys.
    The leak was coming from the bottom of the back seat area and the engine. If this help?
    Ryo
    early 911S registry
    73'E
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Also check the hard line connections on top of the MFI pump. A lot of pressure there and fuel will show up in the area you describe. So dangerous with the heat exchangers right there so be careful. I wouldn't drive it until you get this sorted
    1969 S Coupe #761
    Early S Registry #1624
    Thank you guys again.
    Do I need to change fuel pump if the O ring is not good or I can just change O ring?
    Ryo
    early 911S registry
    73'E
    on a 72 the fuel pump is under the drivers side rear seat.
    i think it is the same for 73.
    sadly once the fuel pump starts leaking it needs a rebuild or replacement and that is expensive.
    not DIY, there are 4 o-rings to replace and it involves complete disassembly.
    bob moglia
    '72 E sunroof coupe
    Thank you very much.
    Ryo
    early 911S registry
    73'E
  1. Need help with gas leak in my 73S.
    By merbesfield in forum Technical Info
    Last Post: 05-24-2011, 06:09 PM
  2. Oil leak
    Last Post: 12-02-2006, 02:21 PM
  3. Oil Leak 2.2
    By Type911 in forum Technical Info
    Last Post: 09-18-2006, 07:47 PM
  4. Oil leak
    By 66-68shelby in forum Technical Info
    Last Post: 08-01-2006, 04:44 PM
  5. Oil leak on 69S
    Last Post: 01-24-2006, 05:52 AM
