Results 1 to 10 of 16
Thread: Tires .... OK I said it. I'm a bit confused
    Apr 2011
    N.Calif., south of SF
    So the old 185/70VR X15 tires are gone except for XWX's from "Michelin" for $500 a tire ....?
    Forgive me but what are some good street tire alternatives? Brand, model and sizes would great be appreciated (Past threads I didn't find in the searches would be great as well)
    Sincerely,
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Jul 2008
    South Florida
    There's always Vredestein... they make a 185/70vr15. http://www.vredestein.com/car-tyres/...classic/sizes/
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Feb 2010
    San Francisco, CA
    Also...
    185/70HR15 AVON CR6ZZ
    You can get these from Roger Kraus, local to you
    http://www.rogerkrausracing.com/
    Great STICKY DOT street tires
    E911SR & RGRUPPE
    '73 S Coupe #306
    Apr 2011
    I just found this tire size calculator- Helpful in comparing at change in tire size http://www.miata.net/garage/tirecalc.html It doesn't calculate fit, of course.
    195/60 X 15 are close.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Jan 2003
    UK
    195/65 x 15 is closer ...
    Andy
    Early 911S Reg #753
    R Gruppe #105
    I just put these Vredestein Sprint Classic on- 185/70R15. Great tires and around $150 each.
    Tires are one of the biggest challenges in this hobby.
    Most everything else, except for oil, brake pads and shocks, doesn't wear out.
    Finding the right size and performance tire for our cars, with a vintage appearance, is becoming a royal PITA (especially if you drive them). The biggest challenge is manufacturers keep deleting and/or replacing the model tire they used to make..
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    FYI on comparison of sizes. List of available brands may be different since I snapped this about a year ago.
    Name:  Tire Size Comparison - Data.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Porsche recommends to install 195/65-15 in replacement as an alternative. Here is the link http://files.porsche.com/filestore.a...d-7350f0aca1db to the complete list of the latest approved tires. I had both XWX 185/70-15 and Pirelli 195/65-15 P6000 N1 ... wouldn't go back to the former after trying the latter.
    Instagram
    Twitter
    Feb 2011
    Spain
    The Michelin XWX are really worth it even of they are expensive. The performance and the look are excellent. They are about the only VR rated tire in The 185 size. You also have Avon, great tire also.
  1. Crank marking? confused...
    By Gytis Kupinas in forum Technical Info
    Last Post: 11-17-2010, 04:31 PM
  2. Now I'm really confused !
    By John Z Goriup in forum Off Topic
    Last Post: 09-24-2009, 05:56 PM
  3. I'm Confused again
    By 70SATMan in forum General Info
    Last Post: 02-18-2008, 02:42 AM
  4. I guess I'm confused...
    By Homemade 911 in forum Off Topic
    Last Post: 10-20-2007, 07:39 AM
  5. Still confused on 69 tool kits
    By Mike Baum in forum General Info
    Last Post: 04-11-2004, 10:35 AM
