Results 1 to 10 of 12
Thread: Hart deep Fuchs on a 71 correct?
    Iam confused if a hart deep 6x15 early (901 361 012 06) its correct or was available on 1971?or if it was the late Fuch No hart (911 361 020 10) ? Someone told me that in 71 models booth were available and I really will like to be sure.
    Also if in the early type it's safe to run the tires with out tubes?
    Dec 2010
    Tulsa
    '71's are generally no heart - hard to find. I'm sure there are exceptions, but i don't remember ever seeing a mixed set (except for spare)
    I had a mixed set + spare on a very early '71.... 3 with, 2 without.
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    To answer the second question; yes, it's safe to run deep sixes without tubes using modern radial tires; just make sure you get the correct (larger) valve stem so they don't leak air. I'm sure someone here (Harvey) can give you the exact sizing for the correct stems.
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    I believe the TR 615 "fat bottom" Valve - I found them at Napa Parts store
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    May 2005
    Oroville, CA
    Quote Originally Posted by Rino71 View Post
    The 71s used the deep 6 (some early cars were mixed with "heart" wheels)) until about 3/71. (workshop manual as I remember)
    Then the 71s used the late (911 361 020 00- 10 is 74 MY>) "flat" 6.
    I have seen the late wheel dated 1/71. Presumably getting ready for the changeover.
    The valve stem issue has been addressed before. The problem occured when the stem mfgs reduced the thickness of the 415 stem above the groove not leaving enough to create a tight fit in the non snap groove wheel. There are still some that will kinda work with some practice. Usually at non tire shops like NAPA or at the bottom of a drawer in an old tire shop.
    We have for quite a while, put in the groove so a snap in valve stem works as designed. There are some photos in a thread....
    Hope this helps.
    H
    Great info! I was thinking selling my deep hart 6, after this I will refinish them for sure. Thanks.
    Aug 2011
    north of the 49th parallel On Can.
    My 71 very early production has deep dish but with no heart at the valve stem 012 dated 1 71 all 5 I've all ways used tubes.
    I've had this car since 79.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Deep Six Valve Stem
    Napa part number has changed a bit recently from other threads posted in the past on this subject.
    I just purchased some a few days ago.
    NTH 90415
    415 is the consistent number throughout part number changes.
    These come in a four pack. There are a few threads in the archives on which ones are the right ones.
    1969 S Coupe #761
    Early S Registry #1624
  1. Winter at the park - a short film by Matt Hart
    By obrut in forum General Info
    Last Post: 07-04-2012, 02:16 PM
  2. 68 Hart Ski 911
    By 50/50 in forum General Info
    Last Post: 08-09-2011, 07:14 PM
  3. For Old Time's Sake - A short film by Matt Hart
    Last Post: 06-28-2011, 09:01 PM
  4. WTB 15 X 6 deep Fuchs
    By jjvirginian in forum For Sale: 911 Parts
    Last Post: 12-07-2010, 06:54 PM
  5. Hart Ski racing team
    By mikehump in forum General Info
    Last Post: 09-17-2009, 06:48 AM
