Results 1 to 8 of 8
Thread: 73 911t fuel leak
    Junior Member
    Mar 2012
    Houston, TX
    73 911t fuel leak
    I have a 73 1/2 911t and I have a leak coming from the hose that comes from the fuel pump to the motor. I have replaced the line and it keeps leaking from the connection to the motor. I have tighten the clamp 3 times which fixes it for a couple drives. Any suggestions on some fixes?
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Are you using " Norma " clamps on the fuel lines? Tightening the crap out of other style clamps just makes them leak more IMO.
    Tony
    Apart from waht Tony mentioned above, are you using the proper metric line?
    Junior Member
    Mar 2012
    Houston, TX
    @rstarga
    Yes. It is the type 3 vw line that matches. As far as the tightening how tight should I make it? Are there any better clamps? Airplane grade?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Let's see some pics of what your setup looks like...
    1969 S Coupe #761
    Early S Registry #1624
    By connection to the motor, you mean fuel filter correct? This is a K-Jetronic car correct?
    As mentioned above pictures would help.
    Jan 2011
    DFW TX
    On my 12/73 MY74 car, there is rubber from the fuel pump (rear mounted) to the fuel accumulator, then hard line to filter, then black nylon tubing from the filter to the fuel distributor on the engine. If you have rubber running to the fuel distributor I think this is a problem. That barbed fitting is made for the black nylon tubing.
    Junior Member
    Mar 2012
    Houston, TX
    I will take picture today and post. Thanks
  1. Common oil leak? MFI fuel pump drive wheel.
    By SRL in forum Technical Info
    Last Post: 01-29-2023, 08:41 AM
  2. MFI Fuel Pump Leak Help
    By 73S in forum Technical Info
    Last Post: 01-03-2022, 02:03 PM
  3. MFI fuel leak, 69S
    By NV Stig in forum Technical Info
    Last Post: 05-03-2013, 09:09 PM
  4. Fuel filter leak
    By FL-Frank in forum Technical Info
    Last Post: 04-13-2013, 02:47 PM
  5. Fuel pump 911T/E
    By amsterdamned in forum For Sale: 911 Parts
    Last Post: 08-09-2008, 02:22 PM
