Thread: Oil Line Engine Compartment Routing Holes
    Nov 2010
    Darien, CT
    Hi,
    We are cleaning up and painting the engine compartment (black like it should be) in our 69S while we have the engine out for a rebuild. I am looking where the oil lines come in and it seems that I have "extra" holes. If you look at the attached picture the lines come in through the top two holes on the left side (where one line still is). I think the holes below them shouldn't be there. Could anyone confirm that they shouldn't before I weld them up?
    Thanks in advance - Scott
    Sep 2008
    Monza, Italy
    Hallo Scott! Never saw so many holes in such a little space!!!
    You are right: the wrong ones are the lowest.
    This photo shows the correct position of the 2 holes, with the correct rubber seals.
    Ciao
    Registry Member #1414
    NOSGRUPPE
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    My guess is the bottom two holes were for A/C lines.
    The other ones are all required, left to right: oil lines, tank mount, thermostat, oil filter console
    1969 S Coupe #761
    Early S Registry #1624
    Sep 2008
    Monza, Italy
    A/c?
    Mmmhhh.. Not the other side?
    NOSGRUPPE
    Here are some great shots of how it should be;
    http://www.early911sregistry.org/for...l-line-routing
    Jeff H.
    72 911
    914-6 GT
  1. wanted: pix of early S oil line routing
    By typ901 in forum Technical Info
    Last Post: 05-11-2018, 11:04 AM
  2. Oil Line Routing Help - SWB
    By John912 in forum Technical Info
    Last Post: 11-29-2013, 01:14 AM
  3. What is the fuel line routing near gas tank (1967)?
    Last Post: 09-12-2013, 08:22 PM
  4. Oil line routing
    By tar356 in forum Technical Info
    Last Post: 07-14-2013, 08:18 PM
  5. Need pics of original fuel line routing
    By Fritter in forum Technical Info
    Last Post: 02-23-2009, 09:45 AM
