Results 1 to 10 of 14
Thread: Finish on a 73 Trans Coupling Cover
    Apr 2011
    N.Calif., south of SF
    Ordered a replace for my damaged trans coupling cover behind the seats and the part came unfinished.
    Anyone know the correct finish? Is it flat black/ semi-gloss black/ does it have a texture or is it smooth?
    If anyone has a picture that would be great as well.
    Thanks for the help,
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    I believe it has a crinkle finish. Not close to the car for a pic. Someone will confirm
    1969 S Coupe #761
    Early S Registry #1624
    My April built '73 is flat black and finely textured ....
    I believe 73 was also the first year the cover was solid and not slatted since a gas heater was no longer offered and the return air feature was not needed. Is that consistent with your cover Chuck?
    Feb 2010
    San Francisco, CA
    My '73 cover is satin black without perfs.
    Just adding another data point.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    No perfs on mine......
    On second thought, mine could have come to me satin black and I might have changed it to flat with a fine texture to hind any blems...
    Aug 2009
    Atlanta
    Ah, didn't realize they went to solid in 73. Could have changed finishes as well...
    1969 S Coupe #761
    Mine came with a fine crinkle finish.
    Oct 2010
    Florida
    Mine is solid and it was satin black - I think. About 15 years ago I had it powder coated in gloss black.
    Richard Newton
    Coupler-cover Finish
    This is a '70 . . .
    . . . semi-gloss black --- but perf'd
  1. Internediate Shaft Cover Plate Finish?
    By DynoDave in forum Technical Info
    Last Post: 09-18-2012, 06:34 PM
  2. FS-early trans coupler cover
    Last Post: 02-15-2012, 05:29 PM
  3. FS-mint early vented trans coupler cover with the wire mesh intact
    Last Post: 07-31-2011, 06:21 AM
  4. FS: 901 Syncro Rings and 1st Gear Coupling Teeth
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 01-12-2011, 05:42 AM
  5. 915 into 901 tub, trans cover.
    By Gburner in forum For Sale: 911 Parts
    Last Post: 08-13-2006, 09:31 PM
