Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: No hydraulic chain tensioner, correct?
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Just bought this 1970 911T on Ebay, and yes I had it PPI'd before finalizing the deal.
    I am assuming this car does not have the hydraulic chain tensioner kit. Is that correct?
    If so, where's the best place (i.e. lowest cost) to buy the kit? Thanks!
    You are correct. I would source them through Pelican Parts.
    Sep 2012
    Toronto
    Quote Originally Posted by Flieger View Post
    Thanks Max. Much appreciated.
    What's the consensus on whether switching to a hydraulic t-chain tensioner is a good thing or not?
    I thought support for this conversion was universal, but I have read some comments elsewhere on 911SRegistry that argue against it.
    Sure, they (Oil Fed) can still fail but the frequency is pretty low and they are a lot better than the originals. Just make sure you get the "genuine article" and install them by the book. The other option are guards you can install on the existing tensioners but if you've gone that far you might as well change them.
    Something else to consider as well. http://www.dietersmotorsports.com/tech/2002/3-2002.htm
    Good luck!
    Tom
    Early S Registry #235
    rgruppe #111
    You can use the 930 tensioners with updated ramps + collars. I think this is pretty much just as reliable a solution as the hydraulics.
    I use the 930 type, disassemble, and refill with 60wt. the late style idlers and tensioner guards. Been doing that for at least 25 years, no failures to date (at least that I know of!)
    Jul 2012
    Claremont,CA
    I think they are 1150.00 ...in stock....
    Marge..
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
    And that, as they say, "is all you need to know".
    Tom
    rgruppe #111
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by nickb4 View Post
    One additional argument against hydraulic tensioners in an Early car, and why many opt for the 930 tensioners with ramps/collars, is the installation requires cuts to the rear engine tin to allow room for the hydraulic lines. That changes the original look inside the engine compartment.
    You are confusing hydraulic and pressure fed. Hydraulic tensioners (930) have no external oil lines like the 84- on pressure fed tensioners, so no tin cutting...
    1969 S Coupe #761
    Early S Registry #1624
    Thanks beh911.
    I'm going to go back and delete my previous post to avoid any further confusion.
  1. Weird Chain Tensioner
    By 911quest in forum Technical Info
    Last Post: 12-20-2009, 07:35 AM
  2. replacing chain tensioner on 73 E
    By cmcfaul in forum Technical Info
    Last Post: 07-16-2009, 06:50 AM
  3. FS: Chain tensioners - hydraulic/oil fed/Carrera
    By kenikh in forum For Sale: 911 Parts
    Last Post: 06-03-2008, 01:24 PM
  4. Chain tensioner upgrade?
    Last Post: 03-10-2008, 03:39 AM
  5. How to ID chain tensioner upgrade on 2.2?
    By ulrichd in forum Technical Info
    Last Post: 08-14-2007, 06:41 PM
