Results 1 to 10 of 11
Thread: Wiring question / oil level gauge
    Max Power ze german's Avatar
    Oct 2008
    Stuttgart / Germoney
    Hi there,
    a few years ago I got my 73 911 t repainted. Since then the oil level gauge is stuck high, as soon as I turn the key to ignition.
    To me this seems to be a wiring problem. I checked the back of the gauge and all connections seem to be fine. So where is the connection to the oil tank located?
    I am quite certain, that the ground cable or any other cable was disconnected while unscrewing the bumper or whatever.
    Best regards,
    ze German
    I can bench press a car,
    I'm an ex football star,
    with degrees from both
    Harvard and Yale
    Aug 2012
    France
    Have you check the oil sender unit located on the oil tank ?
    The red piece in the diagram :
    O-G 26 - Early911S 2407
    ze,
    Two wires go to the two spade connectors on the sending unit accessed under the rear part of the right rear wheel well... I believe both wires are brown, with one having a black stringer. Clean both the connectors on the wires and the spades on the sender, and also try reversing the connection of the two wires...
    Hope this helps
    Check ground.
    Early S Registry #235
    rgruppe #111
    Jan 2011
    DFW TX
    Mine did that when I had a bad connection at the 7 pin connector in the rear - same plug that does the tail lights.
    Oct 2008
    Thanks to all of you!
    But I have to quote Lou Koller: "Frustration, frustration is all we get!!!"
    The cables (dark green and brown) were both disconnected three inches before the plugin under the rear fender. It took me (perceived) hours and loads of bruises to get them reconnected - and in the end it is still not working...
    Today I'll bypass all these stupid cables with two wires outside the car. We'll see...
    Anyway: Again thanks to you all
    Harvard and Yale
    Jul 2012
    Claremont,CA
    to replace the sending unit...do you have to take out the oil reservoir? and how hard is it to replace the oil sending unit? can it be done with just the passenger wheel off? mine is acting up lately
    marge
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by porschegal View Post
    marge
    No you can remove it in the car. Best if up on a rack, but no need to remove the oil tank
    1969 S Coupe #761
    Early S Registry #1624
    Aug 2012
    France
    marge
    No need to remove the oil tank, but the wheel. Pretty easy to do, took me less than 30 minutes. Change the washer also and clean the place and conections.
    Cheers
    Xavier
    Jul 2012
    Claremont,CA
    ill take care of it then....."having hubby take it out then" ...i just got my nails done..
    marge..
  1. Replies: 3
    Last Post: 04-09-2014, 02:23 AM
  2. '68 Normal Sporto Combo Gauge Wiring Question
    By JT912 in forum Technical Info
    Last Post: 04-04-2013, 08:49 PM
  3. WTB - '67 oil level/fuel level gauge and screw on shift knob
    Last Post: 03-31-2011, 11:29 AM
  4. Oil Level gauge jumps
    By Bobs 67S in forum Technical Info
    Last Post: 10-23-2002, 09:44 PM
