Thread: Antenna location
    Antenna location
    I need the placement for a non power antenna on a 69 Targa. I found the placement for a powered antenna on the right hand fender. Is it the same for non powered on the left hand fender or is it different? Fenders are off and being painted, so it would be nice to get it correct. Here is the doc I found for the right hand side. Anyone have the similar page for the non powered left hand side? Thanks for your help.
    Bob
    Sep 2011
    Los Angeles California , subburbs
    powered antenna were placed in the right side of the vehicle..cause there is room for it....non powered antenna were placed on the left hand side...logic being...since the dont retract automatically, they are less prone to vandellisim...cause they have to goaround the car when parked..and its easier for the driver to raise the antenna while in the car...
    lemon
    Oct 2010
    Stockholm/Sweden
    The location on the left (manual version) is not the same as the right side (automatic version)
    I asked about this on the 912bbs and got some answers and went with approx. 89,5mm(115) and 267mm(410)(same measures as above posted pic from workshop manual but for left side)
    Hope this helps!
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Check out the (sideways) picture in this thread as it has the a / b dimensions for the left hand side hole. I haven't seen it anywhere else:
    http://www.early911sregistry.org/for...ight=blaupunkt
    1969 S Coupe #761
    Early S Registry #1624
    Sideways no longer.....
    Hope this helps
    Thank you all very much. That is exactly what I needed.
    Bob Goldman
  1. Location of RS # 181
    By nick-moss in forum General Info
    Last Post: 08-27-2021, 02:05 AM
  2. Location for a Hirschmann automatic antenna
    By Nicklasliljegren in forum Technical Info
    Last Post: 02-23-2013, 08:18 AM
  3. antenna location
    By peekaboo in forum Technical Info
    Last Post: 10-05-2011, 03:08 PM
  4. RHS antenna mount. Hole to interior location
    By oscillon in forum Technical Info
    Last Post: 05-31-2011, 08:47 AM
  5. Vin tag location
    By dave29 in forum General Info
    Last Post: 06-10-2009, 09:41 AM
