Thread: 1966 911 inside door paint
    Senior Member bobm's Avatar
    Northern California
    Trying to finish my 66 coupe and I understand that under the black door panels on the outside edge is a line of black paint. My car is Ivory, does anyone have a photo of the inside area with no panel attatched. Any idea as to the exact location, size/width of the line and color/gloss of the paint that was used? Car was repainted and no reference cars around.
    Thanks for any help.
    Bob
    Feb 2011
    Surrey, UK
    Here's a coupe of photos of my unrestored largely original 66 Ivory coupe (laid up from 1977). As you can see I did slightly 'overdo' the black strip near the top RH corner. Also originally the inner edge was very rough and it looks like it was hand-painted to a masked outer edge. Colour is what I would describe as 'semi-gloss', or a 50:50 mix of black gloss and satin. That's what I used and it looked ok.
    Mick
Size:  92.0 KBName:  P5120161.jpg
    Stockholm/Sweden
    Bob, below is a reference pic from Darryl Deppe´s 912-restoration. I believe satin black is the correct way to go, Würth´s is a nice match.
    http://www.darrylsgarage.com/912/912.htm
    Jesse
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    I think the factory used a brush.
    1966 911 #304065 Irischgruen
    May 2011
    Chelsea, Québec
    I'll take photos of mine at the weekend and post, if you want a fourth example...
    Member #1616
    Senior Member beh911's Avatar
    Atlanta
    I just did this exact project on my car and it came out great. The paint line follows right on the outside of the curve of the entire edge of the door.
    I used Wurth Satin Black and a GOOD tape to get a tight edge.
    I also used a brush like the factory did, and primed the area first.
    When you get to the channel by the A pillar, follow it up the outer edge to the frame. Here's an original paint car to illustrate.
    Name:  008-3.jpg - original paint on 69.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Nov 2006
    S. F. Bay Area
    Yes. Was brushed on. Also under engine lid grille and other area. Very recent post on this.
    Brian
    S Reg #1032
    Brushed on from factory, this is an early '66. After repaint I used SEM Trim Black, worked well.
  1. Black paint in the inside perimeter of the doors?
    By Rino71 in forum Technical Info
    Last Post: 10-04-2013, 09:30 PM
  2. Replies: 2
    Last Post: 06-09-2013, 08:28 PM
  3. Removing Paint From the Inside of a Ducktail?
    By t6dpilot in forum Technical Info
    Last Post: 07-07-2010, 02:27 PM
  4. Replies: 11
    Last Post: 04-23-2009, 12:49 AM
  5. Rubber wedge inside of door
    By caproader in forum Technical Info
    Last Post: 03-03-2004, 08:50 AM
