Results 1 to 8 of 8
Thread: Coil mounting 2.0S 1968
    Dear early S members,
    was there a difference between 68.1 and 68.2 regarding the coil mount?
    I have seen several pictures of 68S engines with the coil mounted on the side (like -67) and also on top of fan housing. Now I don't know if there was a change at some point whatsoever...
    Is there anyone who knows and can help me out?
    Thanks in advance,
    TM
    - twinplugged - 1975 targa former Dutch police car
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    Mine has it on the side now but I suspect it was on the fan housing at some stage.
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    The fan housings changed to mount the coil. Not sure exactly when that happened if at all in 68 but it was the case in 69 onwards.
    Name:  alternator fan shroud chart.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Quote Originally Posted by Porsche-RSR View Post
    Thanks in advance,
    TM
    When the Factory put the CDI box on the electrical console, there was no room for the coil. So the coil moved to the fan shroud. A '68 still has the flat plate electrical console, so if you moved it to the fan shroud, there would be a gaping hole there. A '68 should have the coil on the console on the side of the engine compartment, '69 on the fan.
    Also the CDI coil is smaller and lighter than the Kettering coil used previously, so it's a better fit on the fan without hitting anything.
    I agree. My 68.5 S engine has side mounted coil.
    Dec 2008
    Woodland Hills, CA
    All MY 68 should have the side mounted coil.
    Dec 2004
    SE Michigan
    Anyone have a picture of a 68 with CDI and side mounted coil? Is the same side panel used? Where does the fuel pump get relocated to?
    Bill G.
    EarlyS #718 | RGruppe #437
    Bill, there was a retrofit kit that put the CDI forward of the console, I don't have a photo, but I saw one in a 69T.
    It is possible to put it on the console-- here is '065 before restoration, many years ago. Of course this is not correct but it worked.
  1. Coil Mounting Hardware
    By Tyson in forum Technical Info
    Last Post: 03-14-2012, 09:42 PM
  2. Coil and Coil Bracket Decals
    Last Post: 11-26-2008, 06:17 PM
  3. Coil and coil bracket decals
    By Mike_Moore in forum General Info
    Last Post: 06-11-2007, 08:14 PM
  4. Coil
    By boxster03 in forum Technical Info
    Last Post: 03-23-2007, 12:59 PM
