Results 1 to 10 of 12
Thread: Early interior switches
    May 2011
    Chelsea, Québec
    I am in need of some advice: I just discovered that a PO installed later interior switches or just the knobs (headlight, fog light, hazard light, Webasto heater) in my car and I want to return them to stock.
    Perhaps a dumb question, but here goes: does this entail exchanging each entire switch and knob, or are the older knobs interchangeable with the newer ones?
    The switch bases (above the wooden dash panel) are black, not the later chrome which leads me to think that these are the original switches...
    Any thoughts/advice gratefully received... (also, if anyone has any of the older switches/knobs lying around that they don't need anymore... please PM me!)
    As always, thanks!
    Stephen
    Member #1616
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    Stephen, those are the same as the ones in my early '68. All black and with the rubber protectors over the knob (I have removed these). The rosettes attaching the knobs to the dash can be still obtained but not the fluted knob, on my research. The rosette and the knob both screw on to the switch shaft as I recall. I am not sure what was originally in the '66, however. They could indeed be the originals.
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    I`m thinking that the rubber covers(removeable)wouldn't be correct for a 66`.The rubber ones are a 68 forward USA affair, so the knob is threaded the same as the earlier knobs!Without the rubber pieces,would be correct for 67 and back...Rubber pieces are available now thru various suppliers(autoforeign services on ebay) to make a new home the plastic inserts ....excellent dash.....Cliff
    Hi Stephen,
    Looks like it's the just the knobs that aren't correct for your 66. Believe you are looking for knobs like in the attached pic.
    Darin
    drabb
    1966 911
    1963 356B
    Jan 2013
    Are they not the same, except without the rubber covers?
    Merv
    Member # 2633
    Cars:
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by Merv View Post
    Yes. Just remove the rubber covers and symbol pieces and you should have what you need
    1969 S Coupe #761
    Early S Registry #1624
    May 2011
    Chelsea, Québec
    Thanks everyone for the info... so I have dismantled two of the switches to discover the originals underneath... but: the coloured end pieces are missing! Any ideas where I could find them?
Size:  90.1 KBName:  switch 2.jpg
    Member #1616
    Mar 2006
    8903one
    I`m guessing;You need the center emergency flasher as in post #4 & the other two are okay as in post # 4. If so, just put out a WTB request in the FS WTB section here.Someone will probably have one & you can also trade sell what you have too...Cliff
    May 2011
    Chelsea, Québec
    Thanks again, guys... posted a WTB on the hazard switch...
    Member #1616
    Jul 2011
    Chicago Area
    Thread revival: What is the easiest way to remove the rubber covers from the switch knobs without destroying them.
    Mike Fitton # 2071
    2018 911S Carrera White
  1. FS: Group of early 911 switches
    By s2guy in forum For Sale: 911 Parts
    Last Post: 06-29-2013, 06:27 AM
  2. FS: early igntion switches
    Last Post: 02-01-2011, 11:29 AM
  3. FA: Clearing out a lot of early switches
    Last Post: 01-16-2010, 05:33 PM
  4. Easy Fix to Interior Light Door Switches
    Last Post: 01-31-2009, 06:41 PM
  5. FS: Early wiper switches
    Last Post: 01-01-2008, 04:21 PM
