Thread: Greasing of distributor
    I just purchased a tube of Bosch distributor and do not know where in the distributor to apply it. Does anyone know how and where to apply the grease?
    RGruppe member 445
    Lightbulb
    John,
    A very little bit of grease is applied to the vertical distributor shaft cam lobes where the breaker point arm contacts the cam lobe. That tube will last you a life time...
    Hope this helps
    a little dab will do ya
    Aug 2011
    New York
    Like they said, just a small dab where the rubbing block of the points contacts the shaft. Oiling the felt pad at the top of the shaft, and making sure the springs and weights are moving freely is also a good idea.
    E Sully
    1973.5 911T
    Thanks again!
    RGruppe member 445
    Apr 2011
    N.Calif., south of SF
    ... and saying a dab may be too much. The idea is to provide a film on the distributor lobes for the point set arm to slide across. Too much lube and it will flail all over your distributor and possibly the cap. -->Read: not good <---
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  1. WTB: 2.2T Distributor
    By Irish911 in forum For Sale: 911 Parts
    Last Post: 06-09-2013, 02:06 PM
  2. Replies: 1
    Last Post: 08-03-2011, 10:40 AM
  3. FS: 2.7 RS Distributor
    Last Post: 01-21-2011, 10:31 AM
  4. Distributor
    Last Post: 01-25-2008, 09:34 PM
