Results 11 to 20 of 29
Thread: Visual and Spec Differences for Pistons - 67/68S, 69S, 906
    Senior Member beh911's Avatar
    Atlanta
    Here's the thread with those pics. It looks like they are identitfied by 80P26 which matches with the chart in the first post of this thread. They also appear to be 3 ring, not the oversized 2 ring pointed out in the chart.
    The mystery continues.
    http://www.early911sregistry.org/for...le-906-pistons
    Name:  906 81mm 1.jpg
    Name:  906 81mm 2.jpg
    Name:  906 81mm 3.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Atlanta
    Here's a set of pistons claimed to be 906. But I am thinking they are (were) 69S instead, based on the lack of holes drilled above the wrist pin boss.
    Again, it's still not clear what the real differences are between 69S and 906 3 ring pistons, so I hope someone chimes in with an answer...
    http://www.early911sregistry.org/for...FS-906-Pistons
    1969 S Coupe #761
    Atlanta
    Here's a difference I am beginning to notice as consistent. It shows up between the 67/68/69S and 906 pistons labeled as such in the archives:
    'S'
    Name:  differences - 68S piston side view.jpg
    906
    Name:  differences - 906 Piston side view1.jpg
    1969 S Coupe #761
    You all need to provide dome height and dome volume numbers so you can compare pistons. I have two 906/911R sets here, one used 80mm #80P24 W1. Dome height is 17mm and the dome volume is 36.2cc. the second set is new 81mm #80P26 + E. Done height is 17mm and dome volume is 37.2cc. Both sets have the drilled underside and look like pistons in post #11. Gordon
    there are 80.5 mm 67-68S and 906 3 ring pistons. My early 80.5mm 906 piston doesnt have the drilled holes.
    Atlanta
    A visual reference to NOS 67-68 p & c here:
    http://www.early911sregistry.org/for...-and-cylinders
    1969 S Coupe #761
    Atlanta
    A set of refurbished and measured 67-68S pistons here. Note 80P26 for 67-68S.
    http://www.early911sregistry.org/for...-and-Cylinders
    I think chart in my first post is so ridiculously off base for determining piston application, or this number has nothing to do with a certain piston type and more to do with manufacturing process.
    Experts please weigh in
    1969 S Coupe #761
    Very intersant......
    Atlanta
    Another recent thread:
    http://www.early911sregistry.org/for...-Mahle-Pistons
    And more great reference pics for NOS 69S pistons:
    80P26E
    http://www.pbase.com/9146gt/my9146gt...80p26e_phil_uk
    Name:  pbase phil hindley_uk link - 1.jpg
    Name:  pbase phil hindley_uk link - 2.jpg
    Name:  pbase phil hindley_uk link - 3.jpg
    Name:  pbase phil hindley_uk link - 4.jpg
    Name:  pbase phil hindley_uk link - 5.jpg
    1969 S Coupe #761
    Atlanta
    Another set of 69S Pistons
    80P26E
    http://www.pbase.com/9146gt/my9146gt...80p26e_lorimer
    Name:  pbase lorimer link - 1.jpg
    Name:  pbase lorimer link - 2.jpg
    Name:  pbase lorimer link - 4.jpg
    Name:  pbase lorimer link - 5.jpg
    Name:  pbase lorimer link - 6.jpg
    1969 S Coupe #761
  1. Italian Spec vs US Spec 911S?
    By 73ess in forum General Info
    Last Post: 01-14-2014, 03:10 AM
  2. Replies: 1
    Last Post: 05-25-2010, 04:43 PM
  3. Replies: 3
    Last Post: 04-14-2009, 02:05 PM
  4. Engine Spec. Differences
    By delire in forum Technical Info
    Last Post: 04-26-2002, 06:15 PM
