Results 1 to 7 of 7
Thread: 1970 Fog Light electrical trouble shooting
    Greetings,
    I am trying to get my fog light circuit working after a long restoration.
    The car previously did not have working fog lights so I cannot confirm the circuit worked previously.
    The switch does not light up with a tested bulb. I don't believe that could be caused by a relay but I would like to confirm the relay is wired correctly
    I am unsure which relay is for the foglights. Would someone be able to describe its location in the car?
    I'll have to continue to did deeper if this does not solve the problem.
    Thanks in advance.
    Bob
    1970 911S Targa
    On the road again soon.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Bob,
    It should be the second one up on the relay board/holder next to your fuse panel in the LH front near the battery box.
    Bottom one is for your horns, and the next one up is for fog/auxiliary lights.
    Tony
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Here's a visual for the relays if factory wired:
    Name:  wiring fogs relays.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Aug 2011
    New York
    If you need the diagram.
    E Sully
    1973.5 911T
    Thanks Guys,
    Now that I know which relay is for the fog lights I should be able to get things working.
    My other challenge is to understand why my switch has terminals labeled as 1,2,3.. Rather then like the wiring diagram. N, NR, 58.
    My car is a European car, but I doubt that would make a difference given that the diagram seem generic for NA and Europe.
    Cheers,
    Bob
    1970 911S Targa
    Thanks again all.
    I had a wire loose at the fuse box and a dead relay. Without this help I would have spent alot more time getting this sorted.
    Some new bulbs tomorrow and I should have fog lights for the first time since owning the car. 12years I think now.
    1970 911S Targa
    Nov 2004
    Gold Coast.
    Great to hear it
    Tony
  1. Fuel / Oil Gauge Trouble shooting help request.
    By bobmagyar in forum Technical Info
    Last Post: 06-11-2013, 09:30 PM
  2. Wiper Motor Trouble Shooting Please for '69.
    By t6dpilot in forum Technical Info
    Last Post: 04-21-2013, 11:07 AM
  3. Hella Trouble light NOS
    By Rennman in forum For Sale: 911 Parts
    Last Post: 09-26-2010, 01:51 PM
  4. electrical trouble
    By go fstr in forum Technical Info
    Last Post: 05-16-2007, 10:52 AM
  5. electrical trouble
    Last Post: 05-16-2007, 09:50 AM
