Results 1 to 10 of 12
Thread: 1969 heads
    1969 heads
    I came across a box of 1969 heads dated 9-68 + 10-68. They are for fuel injection. Without measuring the valve size are they 911E or S ?
    Part # 901-104-306-2R.
    Thanks in advance,
    WP
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Those are E heads for 69
    1969 S Coupe #761
    Early S Registry #1624
    which are the differences being for MFI or carburetors?
    Aug 2009
    Atlanta
    Quote Originally Posted by AlexJ View Post
    The main visual difference between E/S and carb (T) heads is the fuel injector port in the intake.
    Other differences exist such as intake/exhaust port and valve sizes.
    1969 S Coupe #761
    Quote Originally Posted by beh911 View Post
    Thank you for the help .......................
    Thanks for the info but I didn't explain myself very well... I mean the difference between S heads 68 (carburetors) and 69S.
    Ok, there's the injector port but apart from that, are the dimensions the same (valves and intake/exhaust portas)?
    The '68S valve size would be; intake = 42 mm + exhaust = 38 mm
    The '69S valve size would be; intake = 45 mm + exhaust = 39 mm
    I'm not sure if the port size is the same ....................
    Quote Originally Posted by WP935 View Post
    Many thanks
    Aug 2009
    Atlanta
    AlexJ,
    Tuck this chart away for reference. From B. Anderson's book:
    Name:  Porsche - 901 engine type summary.jpg
    1969 S Coupe #761
    Thanks beh911!
    Very usefull!
  1. Replies: 7
    Last Post: 03-24-2014, 07:46 AM
  2. Chambers of Cylinder heads 911S and 911E (1967-1969)
    By Elferhelfer in forum General Info
    Last Post: 02-19-2014, 09:57 AM
  3. FS: 1970-73 911S cylinder heads, matched set of genuine S heads
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 03-07-2013, 05:15 AM
  4. FS: 1969 2.0S Heads
    By loopie in forum For Sale: 911 Parts
    Last Post: 11-09-2012, 05:40 AM
  5. FS- Very Nice Used 1969 911E Heads
    By 72tii in forum For Sale: 911 Parts
    Last Post: 10-29-2009, 02:00 PM
