Results 1 to 7 of 7
Thread: Annoying rattle in the driver side door Only with the windows up
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    The car has recently been reassembled after a paint job, It's been so hot I have had the windows down all of the time. Yesterday I had the window up and was cruising on the highway and had a fairly constant rattle in the door. With the windows down the sound disappears totally. Any ideas? I suspect I'm going to need to take the door panel off again but just wanted an indication of where I might need to look. I suppose it's going to be something with the window frame itself.
    Apr 2011
    N.Calif., south of SF
    (Always a good idea to state year and model)
    Did you check the bottom or your door (early model) for a loose bolt holding the window channel?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Jul 2006
    Switzerland
    Sometimes, its just the driver side's door pocket (Hinges, belt and elastic). You only hear it when windows up.
    Make a test drive with the door pocket left OPEN, windows up and maybe the sound disappears. Then you know.
    Happened to me.
    Registry member No.773
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    My guess would be it's not sitting on the runner completely, had the same thing.
    Tony
    Jan 2013
    lexington,kentucky
    It's a 71 911 Thank you for the replies
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by 911T1971 View Post
    Happened to me.
    Start here as its the easiest to diagnose. Check the tie offs of the elastic ends of the pocket support cord. They can rub against the moisture barrier and make an annoying noise.
    If it is a deeper mechanical rattle I bet it is the tracks
    1969 S Coupe #761
    Early S Registry #1624
    Banned
    Nov 2004
    Scottsdale, AZ
    Any strange odors?
    I know sometimes I'll hear a noise from the seat but it's usually accompanied by a smell.
  1. WTB: 69-73 driver side door pocket
    By avantwe72S in forum For Sale: 911 Parts
    Last Post: 01-30-2014, 05:51 PM
  2. WTB: RHD Passenger Side Armrest for LHD Driver Side Door
    By 911030 in forum For Sale: 911 Parts
    Last Post: 05-06-2012, 11:05 PM
  3. Driver side door glass
    By denson in forum For Sale: 911 Parts
    Last Post: 02-26-2012, 12:31 PM
  4. Driver side door?
    Last Post: 05-20-2006, 06:42 AM
