Thread: Early or late spring plate bushings
    Senior Member Jerhofer's Avatar
    Aug 2013
    Rockwell, NC
    My car needs new bushings. I have read that during the year in 1967, the spring plate bushings changed. My serial number is 463127. Would it have late or early bushings?
    1967 912 w/3.0 SC motor and tranny, RS door panels, stock body, power windows & brakes, and A/C.
    http://www.early911sregistry.org/for...us)-1967-912-6
    www.jerryforthofer.wordpress.com
    Aug 2013
    Rockwell, NC
    Since my car was built by Karmann and the first two digits are different, do I go by the last four digits which would mean I still have the early bushings?
    Post a picture of the spring plate cover. The diameter difference is quite substantial. We should be able to tell that way.
    Aug 2013
    Rockwell, NC
    Quote Originally Posted by Flieger View Post
    Looks like the later kind.
  1. SWB spring plate /SC spring plates swap
    By smedley in forum Technical Info
    Last Post: 01-06-2014, 04:02 PM
  2. Replies: 1
    Last Post: 09-25-2011, 08:11 PM
  3. Replies: 3
    Last Post: 12-18-2007, 07:30 PM
  4. 67S rear spring plate bushings
    By Fritz A. Ficke in forum Technical Info
    Last Post: 05-28-2004, 04:39 PM
  5. Neatrix spring plate bushings glue?
    By Wolf Knierim in forum Technical Info
    Last Post: 01-13-2004, 11:13 PM
