Results 1 to 9 of 9
Thread: Black paint in the inside perimeter of the doors?
    Hello, I found this picture in the forum and made me think if I should paint mine like that on a silver 8080-H 1971?
    Was it OEM finish?
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Yes, the original was brush painted but much easier with a gun when you're doing the black.
    The door cards and pockets don't cover the entire door, so you would see color around the surrounds of the trim.
    Tony
    Dec 2008
    Woodland Hills, CA
    This is original on my 68 SWB. It's brushed on and you can some drips as it was applied some what sloppily.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Use Wurth Satin Black to get an exact match of the original factory paint
    1969 S Coupe #761
    Early S Registry #1624
    Will this be the same in LWB cars?
    Thanks!
    Nov 2004
    Gold Coast.
    Yes all the same
    Tony
    You know, after looking at the picture of the SWB OEM door I realize that the black paint does not cover all the perimeter area in the inside, so I ask a Friend and he told me that the purpose of that black sealant was to hold the plastic whether liner that was install at the factory to keep moister out and not for a cosmetic matter.......
    So now I am confused......
    In the picture the door was painted and he will now have to go back and redo the black out to the edge of the door. What holds the plastic liner on is the glue you see as brown areas on the white surface, there is no black sealant used,,,,ever.
    That explains it! Thank you.
  1. FS: 65-67 Pair of doors, still in original paint, no rust
    By 55Outlaw in forum For Sale: 911 Parts
    Last Post: 08-31-2014, 04:03 PM
  2. FS: @Excellence - 1971 911T (Doors Off Paint Job)
    By sithot in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-06-2013, 10:23 AM
  3. 1966 911 inside door paint
    By bobm in forum Technical Info
    Last Post: 02-11-2013, 02:33 PM
  4. Removing Paint From the Inside of a Ducktail?
    By t6dpilot in forum Technical Info
    Last Post: 07-07-2010, 02:27 PM
  5. Correct satin black on inside of doors?
    Last Post: 09-30-2008, 08:56 AM
