Saw this this morning and thought I'd pass it along:
http://www.ebay.com/itm/Porsche-911-...E:B:SS:US:1123
Seth O.
ESR #2474
1966 911 - '77 2.7L Hot Rod
1967 Pontiac Bonneville - '70 455
2000 996
WANTED: 1966 Transaxle 229835-902/1
30+ year PCA member and no mention of whether Engine is matching or not?
Thanks for engine question. Thought I had it in description. Added this morning.
Lynn's ABCs
1961 356b Notchback (90+% finished)
Early 911S Registry #1657
356 Registry #1350
1971 911E Sunroof (Sold)
Agreed. Good thorough detail.
1968 911S
1986 Carrera
2006 Carrera S
VIN = 9111200424
Eng# = 6141560
Eng# = ?
Seller's eBay text . . .
. . . Reluctant Sale of my 1971 911E Sunroof to fund the restoration of a 1961 356 Notchback.
I purchased this Southern car 3/2002 from a young man in North Carolina. I know little of the
early history of the car other than it came originally from Florida. The original color body tag
says 1111-G which is Ivory, but the car has been repainted in white at some time in it's life.
From 2006--2009, health issues meant the car was only started frequently in garage. I have
driven the car appx. 6,000 miles in the 11 1/2 years I have owned it.
The car included an extensive set of receipts for parts and service which I have continued to add
to.
From the receipts, here are some of the major items done with dates & mileage:
2000--Koni Inserts
2001--102,811--Rebuilt front/rear Calipers. (S Calipers)--2 ball joints--turn signal relay
front A-Arm Bushings--4 wheel alignment--clean/repack CV Joints & new boots
2002--Shifter bushing kit
2003--Watershield air cleaners--rebuild Weber carbs
Pressure-fed tensioners were added by previous owner.
Things I have done:
2003--MSD Ignition & Coil--Mangecor Wire Set--19 row-235 mm Fender Oil Cooler--
Gold Porsche letters on rear hood. New carb fuel pump
2004--Hi Torque Starter
2013--105,926--Valves adjusted, heads retorqued and timing set (local shop)
2010--Coco Floor Mats--Por 15 Gas Tank treatment, outside of tank painted, new fuel lines
2011--Bought 1971 Sport Seats. Driver side recovered by Auto's International. Pass seat
original. Set of Sumitomo HTR A/5 P01 tires 195/65 R 15
2013--Clutch cable--voltage regulator
I added the Steel S Front bumper, the Cibie Driving lights with NOS thru-the-grill horn grills and the
Sport Seats with correct 1971 vinyl pattern. Also a period-correct radio that is not working.
Sunroof opens and closes as it should. The trunk lights work.
Flaws:
The paint is not perfect with some chips and other flaws from driving and time.
The driver's side door stay is broken
Needs new Heat exchangers or headers--carbs pop due to holes in head exchangers.
One stud nut will not tighten, so assume it is pulled and needs a timecert repair for
that stud
The transmission syncros are worn in the 915 trans. 3rd and 4th can be difficult, but
the car is driveable. We drove to the 356 event in Helen, Ga from Knoxville in Sept.
I am not a dealer or a car flipper. I have owned this car for 11.5 years. It has been stored in
my above-ground dry garage. There is no Warranty expressed or implied. The car is 42
years old. I would not recommend purchaser driving it home unless a short distance.
I welcome inspection of the car during the auction if you are local. Will attempt to answer
any questions.
Will work with a foreign buyer by delivering the car to a local site for the shipper to load.
Car and title will not be released until funds clear. Cash or wire transfer to my bank for
payment . . .
(Not mine)
Sold today.
Lynn's ABCs
356 Registry #1350
BiN = $35k
Time to start on this:
Lynn's ABCs
356 Registry #1350
Wow. Rare bird for sure
