Happy New Year to Everyone.
After what feels like exhaustive searches on the Registry Forums, specific discussions with Ed Mayo, and scouring old photography on the internet, I feel like I've getting a handle on the differences between US and ROW (excluding Italian market) lighting on the 69-73 911. However, as I'd like to be able to restore them accurately for either market delivery, I'd like some input and clarification on the following "facts" (beliefs?)
PLEASE CORRECT MY TERMINOLOGY WHERE NEEDED (it is confusing reading through other posts on the subject due to varied and general terms used for the specific lights) I'd like to be as specific as possible, it’s the only way I can confidently know that I know something
The Front Turn Signals used the same housing across all markets (US, ROW, Italy)
• For the ROW configuration the Side Marker Light was disabled (base contact removed, power re-routed to Front Parking Light) and a ROW-specific flat internal reflector/lens was used over the socket (tighter, more ribbed pattern than the US octagonal-patterned internal lens.) This internal reflector/lens can be clearly seen from the side of the car through the clear amber portion of the turn signal lens cover on the ROW light.
• The middle socket on the ROW light is converted to single filament by relocating the base contact orientation (using lower screw mount on lower contact in plastic rear cover) and functions as a turn signal only, versus the dual filament configuration for the US light.
• The Front Parking Light on the ROW light is created in the housing with an additional inner divider wall that is assembled into the slot pre- existing in the light housing to create a separate bulb cell to avoid light bleed over into or from the center bulb location. The Parking Light Bulb is mounted into the divider wall and a concave reflector (wall? panel?) is mounted behind the bulb into two slots in the divider wall.
• ROW housings are finished in Matte or Satin White? US market housings have a silver reflective coating applied over the white base finish.
• The Divider Wall and Concave Reflector Panel are finished in galvanized steel? - Or the Silver Reflective Coating?
The Tail Lights used variations on the same housing for the different markets?
• From what I’ve been able to discern from old photos (particularly press release photos of the Carrera RS models) the ROW housing differs from the US housing in the Side Marker Light area: ROW housings do not have a concave bulb socket assembly for a Side Marker Light and simply have the gaping hole in the flat inner wall of the housing, whereas the US light does have a convex reflecting surface/socket in that location. The ROW light does NOT appear to use a flat internal reflector lens according to old photos I've seen on the internet (allowing the hole to be clearly visible outside of the car through the clear amber portion of the Tail Light Lens Cover) versus the US market configuration that DOES utilize an internal lens over the functioning socket/light.
• The ROW and US Tail Light Housings are identical in all other areas except color of finish: ROW are finished in Matte or Satin White (?) whereas US market housings have the Silver Reflective Coating applied over the white base finish.
• A confusing variation I saw while researching threads on the topic was what seems to be a ROW housing with Silver Reflective Coating on the Brake Light and Reverse Light cells of the housing (the remainder being the White finish) - Could this be a year-specific variation?
• Another confusing variation I noted when pouring over photographs on the internet was what looked like internal reflector lens being used on ROW housings on some of the early cars. Is it possible that this is simply a result of US market cars returning to Europe, or did some of the ROWs use an internal reflector lens?
I could not discern whether or not the ROW Tail Lights used the concave reflecting plate that divides the Turn Signal cell from the Side Marker Light area on the US-market variation.
Please chime in here and correct or verify anything you can. If it helps, I’ll be happy to dig up some photos that some of these observations are based on to help get to some definitive answers. Thanks in advance!
