Thread: FS: 1967 911S Engine Case # 960154
    Nov 2002
    Fremont, CA
    Original 67 S Engine Case #960154
    Type # 901/02
    Condition: All original EXCEPT bore spigots were enlarged earlier in life for some 911ST pistons & cylinders (94mm vs. stock 92mm). The case appears to have led a relatively easy life and was not molested or damaged.
    The bore spigots can be sleeved to use original 2.0L Pistons and Cylinders by a competent machine shop. There will be no performance detriment with this procedure and externally it is not visible. Or...you can run 911ST type pistons and cylinders for a 2.3L, 2.5L etc.
    A very rare early 1967 S engine case.
    I have a few other items for a 67S I will be listing shortly.
    $7,000 shipped (worldwide). Trades considered.
    Happy New Year,
    Scott
    scott kinder
    kindersport@gmail.com
    Registry #614
    Oct 2008
    Burford, ON, Canada
    Scott, could you add the pairing number and the date codes off of each half please.
    Nov 2002
    Fremont, CA
    Sure.
    314 (matching)
    date: see attached photo. 5 or 6?, 1966
    scott kinder
    Registry #614
    Oct 2008
    Burford, ON, Canada
    Many thanks Scott. I would say the date is 1966 06; while the one dot is indistinct, it is in the circular pattern, and they would not leave a gap. Plus I have another similar date on a close build #.
  1. UN-NUMBERED basically NOS 1967 Aluminum Engine Case
    Last Post: 03-30-2017, 04:23 PM
  2. FS: Alu. Engine Case 1967 911S
    By BILLY ZOOM in forum For Sale: 911 Parts
    Last Post: 03-28-2017, 05:13 PM
  3. WANTED; WTB 1967 911S with incorrect engine or 1967 rolling chassis
    By almostblue in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-15-2012, 05:43 PM
  4. FS: 1969 911S engine case
    By kenikh in forum For Sale: 911 Parts
    Last Post: 11-02-2009, 08:19 AM
  5. FS 67 911S engine case
    Last Post: 03-09-2009, 11:05 PM
