Results 1 to 10 of 10
Thread: correct color for 1969 S front struts?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    i have koni front struts for my 1969 911.
    The came off a S model.
    What is the correct color for 1969? Black or red?
    www.tcspeed.com
    I would say red.....
    Oct 2008
    Burford, ON, Canada
    Nov 2015
    trying to determine if they changed them to black for 1969?
    www.tcspeed.com
    Oct 2010
    Southern Ca.
    Maybe some were black , but all the original '69's I've seen are red .
    My ‘69 T had original factory supplied Konis....reddish brown.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Nov 2015
    i have installed correct Konis in my 1969T.
    i painted them the same color i used for the heater boxes.
    thoughts?
    www.tcspeed.com
    '69 KONI Shock Color . . .
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    I believe these could be original Konis for this (not mine) low mile (18k), unrestored, 69S. I believe the pinch bolt at base is significant.
    Caveat: I am not a Koni/suspension guy, just sharing what I see on lightly touched cars.
    1969 S Coupe #761
    Early S Registry #1624
    Dec 2015
    NE Michigan
    This is 69 912 that I installed inserts in this summer. Cleaned up pretty good.
