Results 1 to 10 of 15
Thread: Ideal close-ratio gearset for street 71S?
    I have a 71S. I’d like to drop 2nd gear, space 2-3-4 ideally for the peaky powerband so it doesn’t drop below 5200rpm and have an essentially stock 5th. What 901 gearset would you recommend?
    If I move from 185/70/15s to 205/66/16s how will this effect gearing?
    Aug 2010
    Colorado
    [https://tiresize.com/comparison/
    You probably have a GA 2nd. A F second is a little lower. There are a lot of F's out there. I have one and would sell it or trade for your GA.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Agaovza->afjos
    Oct 2010
    Southern Ca.
    There is no ideal gearset . What kind of streets are you driving on ? Flat ? Hilly ? For flat I would say AFMSX , a stock S would be A GA O V ZA .
    This is for driving in the mountains, and I’d like 2nd to pull hard out of tight, uphill turns. Mainly going from Julian to Palm Springs, or up the 79 all the way to Idyllwild, Big Bear, Lake Arrowhead and Angeles Crest Forrest. But stock fifth is nice for the highways between. I’m driving it all the way up from San Diego to Portland along the 1 and then the 101 all the way.
    The main issue is 2nd is too long, and I’d like it tightly packed 1-4 and then as close to stock 5th as reasonable.
    Does someone have a list of the 901 gears? I have a chart showing headsets for hill climb, airport etc but don’t know what the gears in them mean?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by Robofc View Post
    See this thread:
    http://www.early911sregistry.org/for...gearbox-901-80
    Name:  901 Trans ID.jpg
    1969 S Coupe #761
    Early S Registry #1624
    Aug 2006
    Chicago area
    I had an AFMSX gearbox on my 2.2S engined hotrod and had a hankering for a shorter 3-4. I rebuilt a gearbox with the same ratio to an AFKQX and love the shorter 3 and 4. I kind of wish I installed a longer 5th like a Z or maybe a ZA for the highway cruising, but that may be too large of a jump from the Q 4th.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Aug 2010
    Colorado
    This chart might help.
    Chris
    www.reSeeWorks.com
    I have an E,K,Q,V setup with a 904 main-shaft stored away for the rainy day that hasn't happened. A friend used it in an auto-x terror he ran back in the day. Behind a 2.7 he was pretty hard to beat unless you showed up in a 908, which happened to him at a Porsche Parade.
    Early S Registry #235
    rgruppe #111
