Results 1 to 10 of 12
Thread: Vaporized fuel smell - Mech Fuel Injection
    Senior Member Mrzoop's Avatar
    Aug 2012
    Piedmont Plateau NC, USA
    '72 T with original injection.
    After hard acceleration (say passing from 70mph to 95mph) then letting off and slowing back down to 70 - the cabin fills with vaporized fuel smell for a few seconds. The odor goes away almost instantly. I was wondering where I should start looking for the culprit? Any theories?
    - Mark Z
    ESR #2450
    http://letter26.blogspot.com/
    Check your front trunk area, breather hoses fuel level sender gasket, charcoal filter lines and the vapor canister behind the bulkhead cover.
    Are you driving with rear 1/4 windows open?
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Vaporized fuel smell = putting you snout over the top of a can of gas ??
    Check Dave for the obvious. The smell is every drivers nightmare .
    Backing off from 90 to 70 has never created 'exhaust fumes' to come back in via the open Quart lights for me ,, much...
    Mark
    Many cars here have suffered from backwash coming in open rear 1/4 windows, must be the direction the earth rotates up here. I don't drive with them open anymore.
    Aug 2012
    OP here - Yup, now that I think of it I did have the rears open during this long 3 hour ride on the interstate. Only really happened at 70 > 90 and then back down to 70. I was thinking that it might be an injection system gasket leak somewhere. But probably turns out to be back wash from the intake.
    - thx...
    - Mark Z
    ESR #2450
    I have a hard time visualizing how raw fuel smell would come back in with 1/4 windows as these are designed to pull air out of the inside of the car.
    However they would pull fuel smells from the trunk area as they increase airflow through the passenger compartment.
    I get the same smell on mine with the quarter windows open, just something I accepted years ago.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    See post #2 for your solution
    1969 S Coupe #761
    Early S Registry #1624
    Oh trust me, I have, it's not raw fuel, but rather burned fuel
